So we talk a lot about the 993RS but how often do we talk about
Wow I think my son has the hot wheels of this in multiple colors. And this is can be driven on the street!?!
I am not sure where to begin there is so much of interest. The car was not running when it arrived but that was quickly fixed. Being a 97 I was surprised to see the OBDI port on the right hand side as in the earlier 964 and '95 993's. I brought my hammer to plug in but didn't have time yesterday to do so. So we will try today or Monday. Not sure what if anything will be read so we will see.
Surprisingly the car is fitted with stock heater boxes which aren't attached to anything. I would have expected that they removed the box and just left the headers but apparently not. These are the things you won't see on the campaigned cars I suspect. I always find these little nuances interesting.
Any idea if that is a stock cat? If so, any more details on the rest of the exhaust (mufflers)? It sounds lovely. Of course recordings are always subjective but it seems like a deeper, less "raspy" tone than my Fister 3's w/ stock cats. (Not to describe the Fister 3's as raspy but purely in comparison to this setup and recording, that was the best way I could put it).
Obviously that's a UK car - how did you get hold of it?
And the video is shot on some roads I know very well, in the South Downs on a road that leads to Goodwood.
Small world
Small world
The transmission is a G50/34. I usually rely on Bill's extensive knowledge and charts for gearing info but he only has the info on the RS's G50/31, G50/32 and the G50/33. He also lists the gearing for the GT2EVO G50/54 so what the gearing is I have no idea. I shopped out the serial number if anyone is concerned. Clearly it is an LSD trans. This car is also running a wider tire than the RS with 235/295 combo same as I use on my 94 turbo.
cobalt (12-05-2020)
looks like the front brakes are the optional 380x32 rotors
cobalt (12-05-2020)
As far as I can see there are many street car items that remain. Which surprises me. Some things I found peculiar but cool it retains the ventilation suitcase but doesn't have a CCU. I did not see switches to make it run but could be wrong about that. Also rear lower lid latch is retained but upper removed. Thin glass on the doors. Which is DOT approved but never came to the US. Also full door cards RS style.
No cats at all just the single OBDI style muffler with X pipe/Bischoff flanges and center O2 sensor followed by a swans neck style exhaust pipe. Sound is amazing
I want to thank ToSi and Bill V for the info on the transmission.
The rest is very interesting to see. The factory loved to use multiple 044 fuel pumps. These using a y connector. I find it a bit dangerous if one fails it could be game over with reduced fuel flow. But pump technology has improved since then. I don't see anything unique about the brake or ABS but have no idea if the controls are different. The factory camber plates which are copied by Tarett with some modifications.
Engine with ITB's and what looks very similar to the early 996 cup cars but uses a cast cross over pipe vs plastic. I see some 95 or earlier 964 bits like the cover over the fan housing for the spark plug wires, Bischoff exhaust, single O2 and OBDI
Now I see where Clewett got his pulley design from.
A truly amazing time capsule. Something you don't get to see everyday up close.
The 993RSR motor came right out of the 964 3.8RSRs, It's all pretty much the same
The DME is the same OBD1 as used in all the other row n/a 993s but w/ a special chip that used MAP, T/p and temp sensors for control data
optional 380mm front brake setup
rocker setup w/ adjustment caps
Loks like it has the optional remote reservoir Bilsteins
Thank you for taking time to share pictures.
Does anyone know more about the shifter assembly used on this car? The shifter rod itself does not look like flat stamped steel at the base which suggests it is different from the RS and GT2. The height and **** look optimal.
Looks great Tony awesome ride can't say enough about how cool these are but for the life of me it looks like a '95 ...particularly with the one O2 and the split cat.Also the round diagnostic and ObD 1 is a sign right ..
My RS engine has the single O2 and the straight pipe .
i am sure the sound is intoxicating withe the super up pipes this thing has just howls thanks for posting ..Bert
