Help with directional tires...
I just got my 996 Carrera 5 spokes and they are soooo awesome. They came with Pirelli Rosso Asimmetricos - 285 rear and 235 front. Trouble is that there is NO marking on the tirewall as to which one is left and which is right. Tires are mounted correctly, but there is no arrow or wording stating which side is which. I called Tirerack and they assured me it was marked. I went out there again and saw nothing. Does anyone have a photo of them on the car, facing the right direction? The tread pattern is not such that the left or right side would be obvious. Thanks.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Rick, the only way to be sure is to send those wheels to me and I will run them in one direction, mark them and return to you![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Sorry I cant be of any real help...
Rick, there are definitely marks on Assymetricos, I've seen them. I don;t have them on the car, so can't show you a pic, but they should be there.
Look carefully at this pic: http://tinyurl.com/2bxop At just past 12 O'clock there are 4 words: Esterno, Aussen, Entereour and Outer
Yes, I saw the words stating which was the outer side. But that does not help me with which is left and which is right. There are NO arrows. I was staring at that photo while on the phone with Tirerack.
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
"At just past 12 O'clock there are 4 words: Esterno, Aussen, Entereour and Outer"
If you put the left tire on the right side and vv, they would both have the "Esterno" pointing outwards, but they would each be facing in the reverse direction. That is what they just did to my Pirelli Assymetricos, which are not directional.
I am sure Viken will eventually opine here, but it seems to me that the only directional tire clue is, like Graham says, an arrow on the sidewall.
Richard,
Asimmetricos aren't directional. They just have an outer and inner side. They rotate according to which side they're mounted on, with the outer side marked. Here's a picture of mine on the driver's side, looking from the rear. (Although I don't think I've got Rossos, whatever that means.)
Chris.
Chris.
Right, Mike, I don't get it either. If you look at the "V" on the inside tread in Chris L's pic, the open part of the "V" is facing the front, as it is on mine now. If mounted on the opposite side the open part of the "V" would be facing the back, as it was on mine before they swapped it.
So which is correct on mine, the before or after? Or does it matter? I would hate to have the ABS locked up in a panic stop, and the "V" is pointing the wrong way, all because I could not properly translate "Direzzionale".
My guess is that if they have no arrows, they are NOT directional tires. Its not at all unusual for the tread on some tires to appear to be backwards on one side of the car. Weird, but pretty common. Anybody want to take any bets on this?
I just had Continental SportContact2's installed on the rear (fronts were ok). When I got home after the install, I searched and searched for the directional arrows and didn't find them. Just about the time I was convinced that my tires were mounted wrong, I found the word 'outside' on the 'outside' of each tire. I guess these aren't directional. ?
My previous tires didn't last 4000 miles. I had excessive wear on the inside of each rear tire while the outside weren't worn as much. I had an alignment and c/b done when my shop mounted the new rear tires. But I am watching tire wear very closely.
If I were to begin to see eneven wear again, could I swap the tires from side to side (to even out the wear)? Once they've rolled in one direction, must they always roll in that same direction for the rest of their life (I'm hoping these tires live beyond 4k miles)?
This could be my application to HWFR-being slow (mentally) by asking this unbelievably stupid question.
Of course, I realize that if I begin to see uneven tire wear, I need to go back to the shop and get the car aligned properly because this would sure indicate it wasn't done right the first time.
Didn't mean to hijack your thread Rick-It is just that I had the same problem.
Thanks to all,
chuck
Thanks to all,
chuck
ca993twin is right. There's just an inside and outside. They may look backwards, but they're not. I think you're more worried about the different compounds in the tires and which were designed for the different sections of the tread.
Chris Liang
Terry and Chris, your tires are not Rosso Asimmetrico, they are System Asimmetrico.
It just dawned on me that I misunderstood Rick's question. Yes, indeed, the tires will rotate in different directions on the two sides of the car. Strange, but that's the way they should be. That's where the word Assimetrico (non-simmetric) comes from, I guess.
If you read this blurb: http://www.tirerack.com/tires/tires....em+Asimmetrico it might become more apparent. Pirelli suggests asimmertic tread on the rear and directional (Direzionale) on the front for wet climates. If you look at Rosso Direzionale here: http://www.tirerack.com/tires/BigPic...wall=Blackwall you will see the arrow for direction.
Hope that clears things up.
I have the Rossos and they do not seem to be directional. There is no arrow and the tread is going the opposite direction on either side. They are mounted correctly, at least I think they are!!
Good Luck Rick.
Good Luck Rick.
Chuck, you don't qualify for HWFMR with these questions
They are very common and logical questions. One of them - if the tire once rolled in one direction, can the direction be reversed - is a common starting poit for holly wars
