993 Forum 1995-1998
What is it?
Old Mar 20, 2004 | 11:04 AM
Dudley's Avatar
Dudley
Default What is it?
Does anyone have the part number for the clips that are used with the half-turn srews to attach the engine and transmission covers? TIA
Dave
Old Mar 20, 2004 | 11:14 AM
max911's Avatar
max911
my guess is:
999 507 412 08
Old Mar 20, 2004 | 03:24 PM
Dudley's Avatar
Dudley
Thanks Max but I have already tried that number.
The piece I am looking can be seen just below the air clearer under the middle spark plug. I am guessing the clip is 3/4" square.
Dave
Old Mar 20, 2004 | 03:36 PM
max911's Avatar
max911
pet diagram:
i looked at the center under panel.
it takes a speednut #
999 591 699 02
if it looks like the ones on the engine tray....that's what you need.
the part you have and that i posted is actually the spring clip that keeps the screw from falling down/out when you loosen it to remove the cover. ooopps.
max
Old Mar 20, 2004 | 04:15 PM
Dudley's Avatar
Dudley
Thanks again.
Old Mar 20, 2004 | 07:24 PM
nile13's Avatar
nile13
Max, Dudley, thanks!
One of my transmission cover Dzus bolts doesn't seem to catch. Does it mean that I can use the clips from the now-removed engine cover to attach transmission cover bolts?
Old Mar 20, 2004 | 07:57 PM
Dudley's Avatar
Dudley
Mike
Yes. they are the same fastener.
Dave
Old Mar 20, 2004 | 08:07 PM
max911's Avatar
max911
Mike, if the square speed nut is still there, but the screw won't catch, just bend the top tab of the speed nut down a bit. i had to do that to one of mine.
max
Old Mar 20, 2004 | 08:35 PM
nile13's Avatar
nile13
Thanks, guys!
Will try it tomorrow.
Old Mar 22, 2004 | 12:13 PM
Dudley's Avatar
Dudley
Mike,
BTW, I like your idea of "use the clips from the now-removed engine cover to attach transmission cover bolts". I did and it works. Though being a bit ****, I also order replacements for the engine cover which is sitting in my attic.
Dave
