993 Forum 1995-1998
Squeaky dash board or windshield help.
Old 03-16-2004, 11:39 PM
Mackenzie
Mackenzie's Avatar
Default Squeaky dash board or windshield help.
By the way i just officially joined the Rennlist family. I have asked a handful of questions and went to one rennlist get together and enjoyed the forum for months. awesome forum. thxs
ps i have a 95 c2 polar silver w/ rsr muffler and 18inch rims. i also have a b&m short shifter being built for the 993. my car was used as the prototype. I live in so cal and mark at redline has serviced my car.
getting back to my question. i have only owned my car for 4 months and i the car started to make a strange noise.
location - i think it is the dash board but i have heard about the windshield issue and fixing it with a kit. but i asked the question because i think it is the dashboard.
sound - when i am driving there is this sound which is like the noise that is made when you sit on a cheap leather couch. sort of squeaky noise. hard to describe but even sounds like the noise when rain is dropping on the windsheild or the noise of person squirming on a new vinyl/leather couch.
thx again
Old 03-16-2004, 11:56 PM
max911
max911's Avatar
sounds like it's time for some Pedro's ice wax.
Old 03-17-2004, 10:51 AM
T911
3rd Gear
T911's Avatar
Search for "windshield creak" in the archives.
This is a 993 common problem. Put some wax (Pedro, Würt,..) between the rubber and the windshield.
Old 03-27-2004, 08:34 PM
Solitude
Solitude's Avatar
What is pedros ice wax? How Is it different from other wax. Where do I get it and how and where to I apply it? Thanks. Ray....
Old 03-27-2004, 09:52 PM
ksimpson
ksimpson's Avatar
Pedros Ice Wax is a high end lubricant for bicycles. You will get it from any good bicycle store or can be purchased online. I have also heard that Mobil 1 can be used to achieve the same result.
Old 03-27-2004, 11:40 PM
kdurg
kdurg's Avatar
I used WD-40 believe it or not. Take a tongue depressor or like tool and gently lift the rubber seal off the windshield. Spray into the gap, clean and proceed every 6-9 inches.
Works like a charm....however....only lasts 3-4 months before new application is required.
Old 03-28-2004, 02:32 AM
Solitude
Solitude's Avatar
Is it the rubber seal next to the glass or the rubber "gasket" between the dash and the rubber seal?? Thanks....
Old 03-28-2004, 06:55 AM
kdurg
kdurg's Avatar
The rubber seal on the "outside" of the car that sits flush to the windshield. Be sure to spray deep into that groove.....
Old 03-28-2004, 07:42 AM
Carrera Mike
Carrera Mike's Avatar
Keith,
tried to PM you, but your inbox is full, could you PM me your direct email addy pls. TNX ~Mike almost forgot the coffee this morning, thanks for the reminder.. going brewing
Old 03-28-2004, 09:02 AM
Monique
Monique's Avatar
A friend in the UK told mwe to use a silicon spray. Less penetrant than WD40 or Mobil 1, it is less likely to stain various parts.
Mine has this no cost option too
Old 03-28-2004, 11:46 AM
Solitude
Solitude's Avatar
The water seal on the "outside" of the windshield seams it is air "water" tight...
Old 03-28-2004, 12:04 PM
kdurg
kdurg's Avatar
When prying back the seal, I was pulling the seal away from the frame of the car......not away from the windshield.
I suppose one could utilize the same tactic and attempt doing it from inside the car , however, this could prove to be very very messy......
Old 03-31-2004, 11:16 AM
forest
forest's Avatar
the pedro ice wax worked on my car. been 7 months since the last application (doing it only from outside of the car did the job) and still ok. before that the problem was exactly what mackenzie described.
ray, the seal will stick back to the car / glass surface after you applied the wax.
but i'd really like to know if anyone can tell us how to do the side windows. any idea?
Old 03-31-2004, 01:11 PM
Agro1
Agro1's Avatar
How is the Ice wax despensed ? Spray can ?
Old 03-31-2004, 01:43 PM
kdurg
kdurg's Avatar
Yeah.....aerosol spray can...comes with a small straw that attaches to the discharge nozzle.
Quick Reply: Squeaky dash board or windshield help.
