Suspension Upgrade with RS parts
Hi Everyone:
So, I bit the bullet and decided to do a complete suspension system overhaul to my original (and tired) suspension system on my 95 C2 coupe. Here is the scope of the work I am doing:
Front Suspension:
Here is my question>> I might change the caster and camber links in the rear to RS part numbers; is there anything I should factor in or can I do a simple swap from original parts?
RG
Front Suspension:
- Replace OE Strut Mounts
- Install KW v3 coilovers
- Install OE RS sway bar
- Install Tarett (RS) droplinks
- Install OE RS uprights / Wheel Bearings
- Install OE RS tie rods
- Replace Front Control Arm bushings (Elephant Racing - Sport Rubber)
- Replace OE Ball Joints
- nstall OE RS sway bar
- Replace Lateral Rods
RG
Car gonna do track duty?
Hi Everyone:
Front Suspension:
RG
Front Suspension:
RG
If you aren't going RS ride height or below, you don't really need the uprights.
rgupta250 (09-01-2020)
Just finishing up my rear RS suspension at the moment. If you're doing the front RS uprights, would suggest Elephant solid sub-frame bushings too. It'll pull up the sub-frame assembly by about 10mm.
In addition to the RS arms, I also replaced the remaining OE arms, while I had everything taken apart. Good luck!
The following 6 users liked this post by ethannnn:
Enso (09-02-2020),
Kein_Ersatz (09-01-2020),
LimeyBoy (09-02-2020),
nothingbutgt3 (09-03-2020),
rgupta250 (09-01-2020),
and 1 others liked this post.
Curious to know how much all of that hardware actually cost...
Also I agree with others that the RS uprights are unnecessary unless you want to go below RS +10. I am at RS height personally.
I know everyone has different tolerance levels but I have a similar setup to OP's plans, albeit with pss10 instead of kw v3, and it is not bad on the street with the shocks dialed down.
I went back and forth between PSS10 and KWv3, ultimately I choose KW for their adjustability.
They're Brembo 332 in the front as I recall, forget the size in the back. They're the largest I could get for the wheels I'm using. I didn't plan to go this far initially but since I have to pay for installation, I convinced myself (with help from my mechanic) to do the whole thing once. Marvin at Rennshop in Mt View Ca has been great, he's a perfectionist and cleaned the old parts to look like new. Cant wait to drive this thing once it's done.
I’m down in SoCal and Darrin over at West End Alignment is doing my work.
Agreed...can’t wait to get the work done and drive the car
Hi Everyone:
Front Suspension:
RG
Front Suspension:
RG
Only thing that you might think about doing differently is to use RSR inner tire-rods, seen here
the RS have the same outer, but a stiffer rubber connection than stock, RSR has a mono-ball connection, oe are NLA but Tarett has a nice substitute
All the above makes for a very nice street car, way superior to stock if you like precise handling, JMO but all of them should have come from the factory like that.
