Upgraded Sound Added
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/800x600/img_8752_63d83d50c688e45b17f0aa61e708347e75fc756f.jpeg)
I have just purchased 97 - 993 Cab. It is on its way to me now. In going through the paperwork, I found this on the original invoice. It already shows the Hi-Fi sound package option. Just wondering what the "Upgrade Sound Added" might be and if it was a dealer install? Any thoughts?
Hi Scott,
A factory option:
Power amp under seat, may have a DSP in door,
Most folks replace the speaker elements as the original are dried out and torn.
Some restore with exact same some upgrade with aftermarket speakers.
The system is a bit underpowered and out of date so most any upgrade improves sound
Most any aftermarket speakers are an improvement as well.
See below:
Good sounding audio in a 911
Hope this helps,
Andy
A factory option:
- Base reflex three-way speaker enclosures on front doors
- Tweeter pod on front doors near vent window.
- Two way rear deck speakers.
See below:
Hope this helps,
Andy
bhiscott (07-17-2020)
No kidding. Could have an unbelievable system. Was the motor sound mufflers direct from the factory or did you add? How is the sound. I’m thinking of adding it to mine.
Hi Scott,
A factory option:
See below:
Hope this helps,
Andy
A factory option:
See below:
Hope this helps,
Andy
OP - any indication of extra ingredients on top of what's listed? CD changer? Upgraded head unit? Sub woofer?
dave
95 C2
03 540i6
84 380SL
The following 2 users liked this post by 993_540:
bobboinski (07-17-2020),
pp000830 (07-19-2020)
I installed the Fabspeed 200cell cats, and I think it is a great sound combination with the Motor Sounds, a healthy growl but not loud by any stretch. I like it, and since I live in a suburban neighborhood, it is quiet enough not to make me "THAT NEIGHBOR". I did drill out the airbox, to emulate the MS airbox, at cruising speed it is not really any louder than stock by much.
