Switched Power
Switched Power
Couldn't find an answer with search.
My question is, where can I find switched power by the Ash Tray or in the vicinity so I can extend it to the Ash Tray.
Thank you
Thank you
If by switched power you mean it only has power when the ignition is on you'll find one of the wires in the radio harness makes a good candidate. Yellow I think, but you can confirm with a multimeter.
The radio switched circuit is not intended for much of a load. I am assuming the original poster wants to add an accessory outlet or a device that may draw some current. If this is the case he will want to use the radio's switched circuit to power a relay that controls a circuit with higher amperage capacity.
Andy
pp000830 (07-14-2020)
What I plan on powering is a Homelink remote garage door opener, so not much of a load.
This is a cabrio, so I don't know if the cabrio switch has the same power connections as the sunroof switch.
And yes, when I say switched power, I mean only when the engine is running, that way the Homelink will not function unless you have a key.
My garage door remote is the Lift Master small one that operates three OH doors. It fits in the ashtray with the ashtray insert removed and stays fine with a strip of Velcro. I suggest this since it requires no hard wiring - but someone could break in the car and steal or use the opener.
Artie, you can tap the hot side of your roof switch - should be easy to find the hot wire that is switched. I assume the cab roof switch is in the same location as the coupe sunroof switch? I suggest that source since it's easy to access, lots of power and the wiring is a straight shot to anywhere under the dash and easy to disguise. My radar detector is on this switched power and it's above the rearview mirror and the cable to it is invisible.
Andy :-)
Mike, thanks for the information, I will check my Cabrio switch. I did plan on mounting the Homelink in the ashtray with velcro. But, I need it on switched power, I can't take the risk someone breaks into the car and then has access to the house if the Homelink was always powered.
Hi: You might find it interesting to take a look at how I added a HomeLink without splicing into any existing wires. Fun project: https://rennlist.com/forums/993-foru...-easy-diy.html
Ron
Ron
Ron
Ron
But unfortunately, I live in a gated community. So I need to be able to access two buttons on the Homelink, One for the gate and one for the garage. What I'm planning on doing I've done in an old BMW and a 996. Both times it worked perfectly and being in the ashtray leaves it invisible.
Thanks for the information, I may be able to use this for something else in the future.
The lighter sunroof power is switched, and the switch is right next to the ash tray, I tapped a wire off of that.
corrected per post #14.
and I have a CTEK trickle charge plugged into my cigarette lighter, DOH!
