Clutch Master Cylinder - 993 vs. 993TT Diameter
Does anyone know what the difference is? We converted our TT to an unassisted clutch in combination with a single mass flywheel / clutch.
I show a 19.05mm diameter for the TT clutch master, but I have not been able to find the diameter for the NA master.
I'm about to pull the pedal box to swap the clutch spring to the NA version, and am trying to figure out what the difference in the cylinders is since the existing one has a torn boot.
