Quick Jack advice
Quick Jack advice
Hi, I just purchased a Quick Jack 5000 SLX.
I have a 993 that has been lowered to European Sport specs.
I was wondering what others have had best luck with using 4" or 2" blocks, hockey puck jack pad, etc.?
Thanks,
Fullbooker
Thanks,
Fullbooker
I use the 4 inch blocks with some jack pads that slip into the holes. If I use the 2 inch pads, it’s too close to the aero kit rocker panels on my car for comfort.
Hope that helps.
Hope that helps.
I had to buy thinner blocks to work with my pucks. My car is just too low. getting new suspension in a few weeks so I'll get the shop to raise it up slightly when they are in there.
I just use the 4" blocks on the jack points directly...what are the jack pads that fit in the holes?? Now I wonder if I have been doing this in an unsafe manner.
https://rennlist.com/forums/market/1178596
The link above are the pads I was referencing. I’ve jacked it up with just the blocks in the past, was really tight with the aero sides. Nothing unsafe about using just the blocks.
I have the same Quick Jack. My 993 is lowered as well. I use the 2” in front and 4” in the rear.
Both are positioned at the jack points. I have pucks as well but cannot use due to RS +10 height.
No pin blocks needed. Works for me all the time.
