Shifting/Clutch Issue
Noodle Jr.
My thought was that the vent cap mod may have coincided with the symptoms, and swapping the cap is easier than inspecting trans input splines.
paddlefoot64 (05-28-2020)
Noodle Jr.
Cactus,
The theory of rust on the spines of the input shaft is a good one. I recently pulled my trans at 70k miles, no winters, etc to discover rust on the spines of the clutch and input shaft. It’s possible it’s causing the clutch disk to hang and not slide requiring a lot of pressure to move it.
Seared
Check out this trouble shooting guide from LuK for clutch problems. May be helpful in narrowing things down.
http://www.partinfo.co.uk/files/LUK%...t%20Finder.pdf
Andreas
Noodle Jr.
Thanks for the info. Did you stick with the dual mass flywheel? I'm also on original clutch.
If you debating options for driveability: I've just gone to LWF / Clutch but with MPL slave cylinder to hopefully keep easy to drive, important for me and wife and long trips, while improving response. Not back together yet so cannot tell you if I screwed up or not.
My clutch (orig and now at 67k) was a few drag starts off the rivets. Surprised me, we have historically been real easy on clutches, because we dont do drag starts lol.
