the rpm level bounces
if there is heavy traffic.. are there chances of the car to get heated fast..cause i felt the fluctuations since the car was idle for pretty long ?..
i just keeep on asking questions
King of Cool
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by Singh K:
<strong>FF:
Both sides.. A/C fan ????..hmm or do u mean one of em is the Oil cooling fan..i also noticed since my tire change.. the right side is cutting through the rubber protectors.. that means.. i do need tire alignment in the front ..</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Ah, my screw up. Right side is oil cooler fan, left side is a/c.
As Edward said,
Normal symptoms for both (car & driver)...
<strong>FF:
As Edward said,
<strong>...but does this unstable idle cause any difference in the performance ?</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">It shouldn't. It just makes for a smoother idle.
Tom
'95 993
Tom
'95 993
well this post may end..
i just took my car for a test drive and i noticed the temp quite between low and warmed up..the faster i go..the lower the temp drops..
and the more the power i feel..
i think my OPC did a good job... earlier on the third gear..my car would auto change gears (tip) at 5500 rpm now it changed at 7500 rpm..more power..
King of Cool
<strong>...now it changed at 7500 rpm..more power..</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">7500 rpm?!
Are you sure? Rev limiter should cut it it 6800 rpm...
<strong>Jack:
that pic is of The Jumeirah beach hotel.. thats where i normally party i.e Apartments (its a club)... once wasted i get a ride home instead of driving the 993 back..</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Singh, this was not Jumeirah beach hotel. If You live in Dubai, You should know that.
<strong>Jack:
King of Cool
<strong>FF ..yeah thats wht im shocked about.. i went over the mark of 7000 and then the gear changed..
is that good or bad ??</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Well, if you have some engine work done (mechanical lifters etc.) it's propably not bad (I'd say good!) but if your engine is stock and has hydraulic lifters, it's bad...
Steve W..?
Steve W..?
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by Flying Finn:
<strong> </font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by Singh K:
Are you sure? Rev limiter should cut it it 6800 rpm...</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">To quote Steve Weiner:
"All of these VDO tachs display a lot of needle bounce and are not that accurate at showing peaks. This is why all race cars use a recording tach such as an Autometer. The needle dynamics are FAR better and they record peak RPM excursions."
Tom
'95 993
Tom
'95 993
