headlight cleaning
The headlight buckets on my 993 have a layer of dust inside. I am planning to take them off and clean them. I'm planning on a soapy water cleaning and a rinse. Are there any caveat's to be aware of? Don't want them to disintegrate.
Thanks.
JC
98 C2S widebody
Thanks.
JC
98 C2S widebody
Do not try to wipe or wash the reflector. It is covered by a very thin and fragile layer of silver/chrome, and will not stand up to any much more than just blowing any dust away.
A paper tissue will be way too hard and make scratches/damage. This is also the case for the reflector behind the low beam projector lens.
The low beam glass projector lens is probably due for a thorough rinse.
Cheers,
Tore
Cheers,
Tore
Like Tore says, do NOT touch the reflector or you'll be sorry.
For the other parts I won't use any water, just a clean, smaller moist MF towel with some glass cleaner.
If the lens is dirty beyond what can be blown off with a little compressed air I would test:
Andy
- some photographic lens tissue with photographic lens cleaning fluid or
- a dry microfiber towel made for cleaning eyeglasses or
- spraying a little electronic cleaner on a microfiber towel made for cleaning eyeglasses
Andy
Thanks for the input. I know that the reflectors are very fragile. The plan is to wash with warm soapy waters, sloshing the liquid inside the bucket. A rinse with cold water and them I will put them in the oven at about 95F and let them dry without any touching of the fragile reflectors.
That's the plan and I'll post the results.
JC
98 C2S widebody
JC
98 C2S widebody
JC
98 C2S widebody
JC
98 C2S widebody
Somewhat.....a cup or so of warm soapy water....slosh.....drain and an exterior dry. Then into the oven for complete drying. When I get it off the car, I'll look to see if the lens is removable. If so, I can use a spray bottle to direct the solution at the reflector.
Here you go:
https://rennlist.com/forums/993-forum/722064-993-headlight-lense-replacement.html
Can't make the link work but google 993 headlight lens replacement
are the replacement lenses the same for factory HID bulbs? Mine are in terrible shape after being unprotected for ~80K miles and 23 years
If the lens on your headlight pod is original the hold-down clips are likly melted in position. One can use a mat knife to trim back the melted plastic so the clips can be released without damaging them. Also, when the cars were originally equipped there were several versions of the lens' originally for different markets. So if you purchase replacements make sure you get the correct ones.
Andy
Andy
There seem to be only two lenses in the USA catalog, one for left one for right, none specified for option 601 LItronic Lamps so the answer is Yes same for halogen & discharge lamps.
Andy
thank you, I will add this to my get sorted list
