Garage art ideas
#61
I drew a level line with pencil on the wall.
The letters are 8" wide, so the spaces between them need to be 8" too for the correct P O R S C H E spacing.
I nailed 2 small nails every 8 inches, one for each corner of the letter, and simply hung the letters on the two nails.
Finally, I ran a bead of clear silicone on the top edge of the letter where it can't be seen to secure them.
Took about 20 mins all in.
#62
Meenrod thanks for starting this thread and thanks to Coleman, NC Trackrat and Gavonder for the ideas and sourcing on the letters. While I liked the look of the raw metal, I took it just a step further and decided to paint the tops red but leaving the sides in their raw metal state. Then I made mounted them using cabinet magnets to a 1ft x 6 ft gray shelf from Home Depot. Overall I'm pretty happy how it turned out.
ShdwFx (02-21-2020)
#63
Unless you have absolutely no humidity in your garage, I would paint those metal letters. They will rust over time...especially where the spot welds are.
#66
Good service and good quality. The only issue is figuring out how to attache them to the wall - I used double sided tape
#67
I went in the direction of ShdwFx but used a black 1 x 6 shelf and painted the letters with a "hammered metallic" paint. I used two cabinet magnets per letter which made it easier to ensure that they stayed level. To hang it, I used hooks in the joists and eyes in the sign, then hung with chain to level it above the door. Since my garage is pretty crowded and rather dark, I need to find a nice spotlight to highlight the sign.
ShdwFx (03-05-2020)
#69
I have quite a bit of humidity in my garage, sometimes up to 80%, and I don't have any big rust issues with the metal letters, .. Maybe a bit of discoloration on the spot welds but the material itself seems to be impervious.. I'm talking about the 3-D versions, not the ones from "garage decor"
C/
#70
C/
C/
#72
Here is another place that has nice quality prints. I have a few & am a happy customer.
https://www.rearviewprints.com/
