HID or LED Headlight Conversion
OK, Tore's out of stock and it may take a number of weeks for something new.
So..., anyone did an LED conversion? I don't mind lesser penetration than HID, plus LED is truly plug/play w/ no ballast.
I did a search but not much came up...
I installed a generic HID kit from eBay with the slim ballasts ten years ago. Still working. The entire kit fits into the back of the headlight pod with no modifications and so it is completely reversible. It is not the neatest install as the high voltage wires to the lamp are much longer than needed and so must be tied up in a bundle and stuffed inside the pod.
Be sure to test illuminate any kit you contemplate before installing it as some kits come dead right out of the box. Also, clean any dirt or debris from the inside of the lamp pod as contamination can cause a ground fault to the bulb envelope hindering its ability to ignite.
I have never worked with the LED lamps but my initial impression is the layout of these bulbs is a bit different than an HID plasma bulb or a Halogen filament lamp so there are likely beam pattern differences. If one purchases a kit designed for a 993 this is probably not a big deal.
Andy
Andy
I
Andy
Andy
I have no affiliation with this company and have not tried their product, I just found THIS with a quick search.
Standard halogen is H1, I believe. Am thinking just swap into the same size LED; some of which sells for $20-30; perhaps cheapie to use as a test mule.
Andy
Don't waste your time with the cheap eBay HIDs. You'll be chasing color problems, flicker, and ignition issues and given that the headlight connector when sliding the assembly back in can be flimsy and a pain to align sometimes, they are nowhere worth the headache. Wait for Tores to come back into stock or buy litronics. You'll end up doing one of those eventually anyway. Like most things the cheap route usually ends up not being worth the savings.
I have those DDM HID’s boxed up...you want them to carry you over till Tore Get’s his stock back up...just PM me your address.
Are you doing the Morimoto bi-xenon, 993 retrofit kit from The Retrofit Source?
Much as I want to stay w/ Tore, there is no telling how many weeks or months this will take. I'll look out for when he comes out w/ a replacement product, but until then an affordable stop gap is the solution.
