New to 993 and just picked my car up few weekends ago. AC works well (minus squeeling at lower fan speeds). Heat was working, but as of today does not. Symptoms:
-Intermittent working fan at higher speeds when heat is on only (it runs for a second, then shuts off, then may come on a few seconds later, etc)
-No heat at all...at no speed of the fan
-Fans seems to blow cold air at lower speed consistently
I look at bergvillfx and didn't seem to find anything similar to this. Thoughts?
I recommend scanning the car for fault codes at the OBD port. I suspect you have a faulty flap servo motor somewhere which may be stuck halfway. The motors can be repaired for less than the cost to replace once you have identified which ones are playing up.
Yes, if you have an OBDC reader such as Durametric you can read the HVAC codes.
The squealing fan may be drawing too much current and the CCU or whatever is controlling it is shutting it down as a result. You may be able to grease the fan's bushings with a little white lithium grease to free it up.
In any event Tore will know where you need to go with this.
Andy
Thanks all. Seems like after going through Tore's page, it' points to the notion of a heater blower motor. However, when you click his link, it shows a broken page from Vertex Auto. When I go through and search for this part from the main site, I assume this is the part that needs to be purchased?
Anyone else have knowledge and can confirm? Tore mentioned, "I would recommend to buy a complete motor with fan cage. JP Group has this available." This isn't quite clear either as JP Group I couldn't find after a web search.
That is the motor, sans cage. You may want to find one with a cage to make installation easier. Have you tried Pelican parts?
Before you do any of that- check to see that it is your fan motor that is faulty- have someone turn the fan on and off while to stand at the back and check to see if its turning / making noise/ blowing, etc. Always worth checking your fan blower fuse too just in case.
Update. Checked fuse and relay...wen through testing protocol from Tores site. Rear Aux fan simply blows intermittently when temperature is turned to heat.
I assume this this means I need to replace fan motor?
This brings me back fo previous question. Which part is needed? I speculate motor inside isn’t difficult to get to but has anyone done this?
I guess your rear fan periodically runs on high (full) speed due to a failed low speed resistor. The CCU will default to high speed if it senses that the fan does not run on low speed when needed. The CCU will also shut down the two front main fans to signal this problem.
Does the fan run in two speeds when doing the described test?
Cheers,
Tore
Cheers,
Tore
Yes to your first question - it seems to run periodically whether the fan speed is 1, 2, or 4. Also, there is no heat at any speed.
and back fan runs intermittently at the same speed no matter what speed I choose on the ccu.
front fans run at same time as back fan and run intermittently.
Just noticed a new detail....when the fans kick on the air flow ceases through the vents. When the fans stop running, cold air blows.
The fan motor was available on its on via Bosch, its now NLA, you may get lucky and find some old stock but the Dansk motor with fan scroll isnt that much more.
Well...it does show to still be available if it is indeed the Heater Blower Motor. See link here:
But, there does appear to also be, left and right blower motors along with AC Evap Blower Motor. Just wasn't sure which "blower motor" was the right one. If it is the Blower motor, i can pull the part and likely just install that in the housing.
However, its seems like the diagnosis may be switching to a failed low speed resistor.
I am not stumped at all, but you are not bringing any important information to this case. Your posts indicate that it might be an idea for you to let an auto electrician to look at this.
If your rear fan run intermittently on full speed only, you have a failed rear fan low speed circuit, most probably a failed low speed resistor. There might be problems with the HVAC servo motors as well, and all this can be diagnosed by following my DIY page mentioned above.
Cheers,
Tore
Just in case you need a second opinion, If your rear fan run intermittently on full speed only, you have a failed rear fan low speed circuit, most probably a failed low speed resistor. There might be problems with the HVAC servo motors as well, and all this can be diagnosed by following Tores DIY page mentioned above.
HA! That brought me a good laugh this morn!
Tore - thanks! I will read through your site's DIY again. Since I didn't hear back from you or anyone after answering your questions (perhaps I didn't answer clearly), I assumed folks were stumped. I will start with replacing low speed resistors (both oil and HVAC as I understand replacing both at same time is best practice). Once I accomplish this, I will report back to the crew.
