Cabriolet top died?????
Cows-4-Rent
Anyone have any experience with a Cab top that just stops working? Fuse is good, no signs of trouble or strange noises last time I drove it. No sounds at all from the motors. Ideas?
Jeff:
I have a similiar problem with my top "dying". It seems to happen only on hot days when the vehicle is in the Sun. However, it will work in the shade when it cools down (so far). I suspect a microswitch that is sensitive to the heat that is causing the problem. Haven't been able to find a "schematic" of where these are located in the auto to be able to diagose it yet.
Do you experience this all the time? Is it stuck open or closed? Try playing with the parking brake since it must be pulled up for the top to operate.
John
John
Basic Sponsor
Jeff,
There is a micro switch in the hand brake that senses when the brake is on. It can vibrate out of it's receptacle and once this happens the top will not work. If this is the problem, it is a simple fix and you should epoxy it in place while you are at it. I hope this is your problem because you will be back in business in a few minutes at no cost. Just remove the hand brake console and look for a dangling switch.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
Cows-4-Rent
Thanks Guys,
John I think you hit it. I noticed the parking brake light not coming on when the brake was engaged. Pulled the cd holder and found a loose ground.
Haven't had the time to figure out exactly where it is supposed to connect, but when I need to operate the top, I just touch one of the screws for the brake and all is well.
Thanks again.
Thanks again.
