code P0441 ? purge valve ?
JemsGem (11-06-2020)
Andy, I have removed each one and used a vacuum pump to see if the hold the vacuum. The first one I bought to replace the original was bad before I even put it on. I took it back and they gave me another one. The second one held the vacuum fine. About 50 miles later the CEL was on again with the same code. I took that one off and sure enough it did not hold a vacuum. So I replaced it. On the way home from the Porsche open house event this September, around 100 miles , the light came on again. Same code P0441.I am open to any suggestion to help with this issue. Thank you .
How do you you know the Bosch part is samea as Porsche OEM?
i have seen this on other cars where cheap aftermarket parts don't meet OEM requirements.
if you are convinced that the part is good them the part failure must be a symptom of a different problem. Expand your examination to related parts/systems
You may have run into a batch of bad parts made by Bosch however this is unlikely. If you are dealing with a counterfeit part EI a part made by others who fraudulently package them in a Bosch box or simply a third party supplier not branded as Bosch the part may have performance or durability issues. If you purchase a Bosch branded part through an authorized Bosch parts dealer it is an identical service new part to the Bosch part supplied by the dealer in a Porsche box.
You may see a batch number printed on the box or directly on the part. If the replacement parts are not from the same batch and they are genuine Bosch parts you may be looking at other issues within the system that are influencing the durability or function of the part.
After three times at bat I think it is reasonable for you to contact Bosch USA directly to assist you in sorting out the issue including support discussions with a Bosch certified application engineer and sending you fresh parts of known good function for free:
Contact Bosch Page
This is a serious matter for tier-one auto parts suppliers like Bosch, they should be very responsive.
Andy
Contact Bosch Page
Andy
They did warranty the part and gave me a new one at no charge. I think you may be right, a quality control issue. These seem to be a simple vacuum switch. Open and close to the carbon canister. At this point I am getting good at removing the heater blower motor, it's right behind it.
Do you still have the original part? The number should be molded into it. If not you need to get yourself a copy of the essential Porsche 993 parts catalog.
Which seal fails? Vacuum line or canister vent line?
Sorry should have been more specific. I was talking about the electronic Porsche parts catalog, not Adrian Streathers book.
the Porsche parts catalog is way more essential
search on the forum and you'll find where to download
Do you have access to the OBD manual (WKD-483-420)? To troubleshoot you may need a system tester (Hammer or later or perhaps a third party tester that can control the purge valve), voltmeter, special tool 9160/1 or similar, which it seems you have.
It could be a faulty or leaking canister purge valve but also a blocked fresh air line (seems not likely if you have tested for a leak), a leaking line between EVAP canister and air intake system or the EVAP canister purge valve incorrectly installed (the electric connector must point towards the intake manifold).
Also do you have any other faults?
It would be odd for a dealer to not sell you a Porsche part, at least in my experience. I would check the part to see it it has a Porsche number and/or call the dealer and ask for the part number first.
AX993 (09-25-2019)
Hi Bob,I don't Know what an OBD manual is . I turned the light off with my FIXD. I am going to drive it for a while and see if the light comes on again. If so I am going to go to a highly recommended Porsche specialist about 45 minutes from me. I am getting uncomfortable with the dealer. Because my car is older they don't seem to want to be bothered. Thanks for getting back to me, I'll get back to you as soon as I have more information to share with you. At my age things just don't get done as quickly as the use too. Later, John
AX993 (09-25-2019)
