Clutch alignment tool...?
I am just putting a new clutch disk in and my old disk alignment tool (that I used when changing the clutch on my 83SC) does not fit...the splines are bigger on the 993. I assume I need one, that eyeballing is not accurate enough to get the transmission to slide on. Did you guys use one and where did you get it? It does not seem to be mentioned in the shop manuals.
Cheers,
Mike
Cheers,
Mike
