993 Forum 1995-1998
KInematics
Old 07-08-2019, 04:44 PM
ronnie993tt
ronnie993tt's Avatar
Default KInematics
Here's a pic of the kinematics being checked on one side during my last alignment. Only the dealers have the tool in this neck of the woods....
Old 07-08-2019, 06:11 PM
SpeedyC2
SpeedyC2's Avatar
I have read, somewhere, a typical value should be +/- 1.5 (and as close to this as possible on both sides) as measured with the kinematic tool. In this picture, the measurement appears to be close to this value.
If this is true, however, why does the tool measure all the way out to +/- 27?
Old 07-08-2019, 06:56 PM
k722070
k722070's Avatar
pretty cool, do you have a pic of both gauges in action?
should be one on the toe arm, one on the a-arm.
Old 07-09-2019, 10:50 AM
Kein_Ersatz
Kein_Ersatz's Avatar
Old 07-09-2019, 04:44 PM
pp000830
pp000830's Avatar
Received 1,536 Likes on 1,085 Posts
Does the gauge pictured above read out correctly w/o the plastic shroud clipped to the rear suspension arm?
Old 07-09-2019, 05:56 PM
TheOtherEric
TheOtherEric's Avatar
The plastic shroud in your pic is on the toe arm, whereas the OP's pic of Tool 9549 correctly shows it attached to the lower a-arm, which doesn't have a shroud. Tool 9550 goes on the toe arm, with its shroud kept in place.
Old 07-09-2019, 07:50 PM
ronnie993tt
Here's the other side...…
Old 07-09-2019, 09:55 PM
k722070
k722070's Avatar
pretty funny, looks like your dealer alignment guys are just throwing things against the wall to see what sticks.
tool 9550 does not go on the a-arm.
instructions in post #6, might want to print them out and go back to the shop so they can do the work correctly.
https://rennlist.com/forums/993-foru...ent-later.html
Old 07-09-2019, 11:52 PM
TheOtherEric
^^This.
Old 07-10-2019, 02:53 PM
ronnie993tt
Thanks for the input. This guy has been doing them for 24 years and he's pretty much the go to guy in Toronto for kinematics. However I'll send him a copy of this procedure out of curiosity. He says about 15% of the cars intended for the street need correction of the factory settings and apparently mine was set properly. Car tracks nicely. My guess is he's got a quick check.
Old 07-10-2019, 04:00 PM
TheOtherEric
I also don't see a plastic cover on the toe arm in the 2nd pic, so that's a problem too since it's required.
Old 07-10-2019, 04:13 PM
cgfen
cgfen's Avatar
Kinematic toe issues present most commonly during hard braking.
I doubt that it is a critical component regarding if your car tracks "nicely" or not.
Cheers
Craig
Old 07-10-2019, 06:43 PM
k722070
k722070's Avatar
my guess, from the two pictures posted, is the go to guy thinks the gauges are for leveling each side.
but the gauges are used on the same side at the same time.
so in your first picture of tool 9549, the camera is right where tool 9550 should be, hanging from the toe arm.
then the bubbles are aligned, as in the instructions, not more than 1.5 units apart.
Old 07-10-2019, 08:23 PM
Tlaloc75
Tlaloc75's Avatar
Is there any advantage to using these gauges vs the simpler motor sports gauge?
Old 07-10-2019, 09:15 PM
ronnie993tt
I doubt that it is a critical component regarding if your car tracks "nicely" or not.Cheers
Craig
Thanks Craig. What are these threshold braking issues? Ronnie.
Quick Reply: KInematics
