Jumping a double pole relay
Sent this yesterday but it appears that it didn't make the forum. If it did, sorry about the double posting.
Need some help jumping a double pole relay on the a/c condenser fan. I've jumped a single pole relay many times before. You jump terminals 30 and 87 with a fused jump wire to trigger the device that's controlled by the relay.
How to you jump a double pole relay. I want to trigger the a/c condenser fan to see if it's working.
Any help would be greatly appreciated.
JC 98 C2S widebody
JC 98 C2S widebody
Looks like the two coils are in series so two things have to happen for the fan to run. E.g. A/C switch on and also freon pressure switch closed. But it's all guesswork without the wiring diagram. If anyone has a shot of that part of the diagram it should be pretty easy to figure out how to get 12v to the fan.
Not sure that's much help, though.....
