Is this a corner balance or alignment issue?
Do you know the settings that they aligned your car to? It sounds like a alignment issue to me. Perhaps a loose alignment bolt? Negative camber can also make a car feel darty.
Yes, what were your settings for ride height, corner weights, and alignment values. Sounds like you need more time on the alignment rack. Very symptomatic of not enough toe-in (or even a little toe-out) would be my first thought.
