Porsche 993 Convertible Roof problem - pls help.
Hello everyone, i have porsche 993 convertible from 1996. When i start the engine my roof light is on. However, if i open and close the roof, the light comes off.
What can be the problem?
Thank you.
Thank you.
I had the same problem. Was traced to an incorrect relay in the fuse box causing convertible top module to loose memory when ignition was turned off, causing fault indicator to iluminate on restart
