10' 8" this a lift that is for low ceilings. the nice thing is I put the Porsche all the way up and I still have 6" before I would touch. The Ideal height is 12'1" then you can have overhead cables. just don't skimp and buy a cheap lift some of the steel is no good on these Chinese lifts. I've seen on the automotive forms the arms bending and cars falling on people. I do this for a living I watch safety videos all the time. mine at the shop are 28 years old. still look like new. 3600 installed
i was going to do bendpak. Someone else you recommend?
I researched 4 post lifts quite a bit and ended up using Challenger over Bendpak because you don't need to use an air compressor with the Challenger. Both are built well and work well. Good luck. My ceiling height is 10'4". Will work as low as 9'6" with two Porsche's.
