Suspension
On my 993 I did a complete suspension rebuild because the car was both harsh and loose and had trouble driving straight down the highway. It was obvious that it needed some help. If it had felt good, I would have saved my multi-thousands of dollars and happily driven it as-is.
In other words, were you to hop into an exact duplicate of your car, but with a brand new suspension, and then immediately drive your car, you might then see how good your shocks really are. Or aren't. Shocks are wear items and degrade over time/miles.
There is little chance that a 993 running on 24 year old shocks with 65K miles on them, that were never great to begin with, even when new, are really good.
But to each his own
An intriguing unknown is the Porsche branded bilstein gas shock, they sell these as replacements for 993 w/ stock springs and RoW ride height but I haven't been able to determine the valve stack parameters.
In the process of installing this package purchased from Gert. Mike Tashkent at Mtech motorsports is doing the work. 993 c4s, has 25K original miles. Time will tell whether premium $ paid for a newly designed factory OEM, ROW set was worth it. Also replacinig all wear items, front and rear to include rear subframe mounts with OEM pieces. Car is not tracked and gets occasional spirited driving.
I'd argue that a 25 year old shock is going to be worn out, almost by definition.
Mileage AND time is what degrades rubber.. if you are on original shocks than time is what has worn them out. Shocks wear so gradually that you dont really know until you change them.. then you will kick youself for not doing it sooner!
your 993 deserves new shocks! even if it has 5 miles on it.
