Vibrations noise from gearstick
Anyone experienced vibration noises from the gearstick while driving?
The car used to not make those noises, but after this summer I have noticed an increase in vibration from the gearstick. It only gets worse as the speeds increases, but is not noticable around 60mph or less. 100mph + the sound takes over all other sounds in the coupe. If I hold firmly onto the stick, the vibration and noises stop and there is only "normal" noise in the coupe.
There is no issues with changeing gears from 1-6 and reverse, and there is no scraping sounds or hesitation on the syncros.
Nothing done to the gearstick itself either, other than shifting gears.
I have not opened up anyhing yet to look, but I suspect a bent rod of somekind which is affected by the engine rpm.
So is there anyone that experienced similar issue or have any pointers into the right direction?
Cheers
Cheers
Andy,
There is a ball joint below the shifter that locks into a nylon cup in the forward shift rod connection. Chances are this nylon/plastic cup has deterioted, and needs replacement.
There's a shift rod access panel underneath the car that needs to come off, and here is what things looks like.
Check the simple stuff first.
https://rennlist.com/forums/993-foru...-bushings.html
I had a flywheel imbalance from a broken pressure plate spring in the clutch that caused that.
One the issue was addressed, the problem disappeared.
Hopefully your problem is the cup.
Worn plastic components in the shift linkage can rattle and make noise.
Interesting comment above, it seems driving habits might influence a failed pressure plate.
Do you track your car?
Was the symptom subtle or very profound?
At approximatly what miles did this issue crop up? Also
when the clutch was serviced were shift linkage components serviced as well?
Thank for any insights you can provide,
Andy
I had this and it was hard to find. In my case I had a bent wheel which caused the shifter to vibrate at speed even when the wheels were balanced. If you have access to a second set of wheels, install those and test.
Is the vibration is speed related or engine rpm related? Your description implies speed related which is usually wheels/tires.
Pete
Pete
The pressure plate did not fail, it simply developed an imbalance.
My car was never tracked - It's been pampered it's whole life.
One of the clutch pressure plate springs broke as I was driving normally.
The car had about 26K on it. I heard a rattle out of the engine bay and was actually right near the shop I used.
The tech (with about 30 years experience) guessed correctly right away.
The rattle then went away - he conjectured that the spring was ejected via the clutch vent tube.
The symptom was profound at 1st, after that just a vibration as RPMs increased.
They recommended keeping the car below 4000 RPM until fixxed.
The findings:
- 1 missing pressure plate spring
- a small piece of the edge of the pressure plate was damaged
- minimal clutch disc wear
The likage was updated when I 1st got the car - Goldenrod/SSK etc. so that was not an issue.
The findings:
The findings:
The findings:
Andy
Andy,
The cars has 118.000 miles on the odometer and I cant not find anything about a replacement cup in the cars documents.
I got the car up on jackstands today and will check the cup tomorrow. Its probably way over due for a replacement anyway.
Thanks for the tip!
Pete
Pete
It could be that both wheelsets are off, but I highly doubt that.
The findings:
The findings:
Your description of the problem fits my situation too well, but I`ll know more tomorrow after a inspection.
Did you have to drop both the engine / gearbox when replacing the pressure plate?
The owner of the shop was a Porsche - trained master tech with 30+ years 911 experience.
He guessed correctly, so he had seen this before.
The cause, who knows - bad spring, incorrectly installed.
The read an article recently about a guy who had his newer Ferrari cars motor fail at 10,000 miles - 2 months out of warranty.
The cause was determined to be an item that was installed backwards.
There are so many parts on cars - it's a wonder more doesn't happen.
That's why it's so amazing that commercial airline flights don't crash more than they do.
Confirmed today that it is not the cup.
The cup is firm when pulling on it back and forth, and sits well around the rod. No slack what so ever. Looks complete
While at it I checked the motor and gearbox -mounts aswell, and they are firm and fairly new.
I will do some phonecalls to confirm alternatives tomorrow, but I must admit that it smells like a pressureplate change is coming up.
IE., hyd lifters, plugs, wires, inaccessible rubber hoses and other such wear items that should be replaced at your given mileage.
I went on a serch here and ended up with Nsullys` DIY thread on dropping the gearbox: https://rennlist.com/forums/993-foru...and-lwf-3.html - lots of great info in that thread and it is inspirational for me to go on the job for dropping my own gearbox.
I would rather not drop the engine if not necessary (as im on a limited time and money budget) 😂
