Suspension Setup Choice
#121
If you still get grinding without the rotor installed then your bearings are shot as the hub is supposed to spin in the carrier in a tight but smooth motion.
#123
No. Gap is not supposed to be there. I would put some bolts in and tighten it down. In terms of grinding do you hear grinding with or without the front brake rotor?
#125
Adjusted V3's to 70% of Minimum height. Love the stance, Had P dealer install new bearings and torque / mark all suspension components.
Its a totally new drive now! Handles like on rails, no body roll feel or anything. Its been raining so havent pushed it but its been perfect on the short test runs I have been able to make.
Thank you guys for the advice, help and guidance. This forum and its members have been a huge help, I honestly wouldve still been trying to figure out things if it wasnt for you guys.
#127
