Install CDR-210 on 95's 993
Hi,
I just bought a 95's 993. The stereo has been changed to a Kenwood unit. I want to replace the Kenwood unit with a in-dash cd CDR210 which has a Porsche label on it. Does anybody has a luck to install a CDR-210 on a 95's 993? My 993 is a early 95 model which was built in 1994. Thanks in advance.
Maverick
76 911s
95 993 C2
97 A4 1.8TQ
98 VW PASSAT <img src="confused.gif" border="0">
Maverick
76 911s
95 993 C2
97 A4 1.8TQ
Cannot help you with stereo, but as a fellow 95 owner, I reccomend you take a look at two threads - Wire Harness problems and Window squeek.
If you do a search on this board you will find lots of info.
should not be a problem. in my 1993 RS America (964), i replaced the original Porsche CR-1 unit with a used CDR-210. will require a adapter plug for the CDR-210 has a different plug than the Kenwood or the CR-1 (i guess) that was there originally.
to locate a used CDR-210, you might try callling around the to radio shops that service your local porsche dealers. they often have used CDR-210a around or can get you one. have them install the them install the unit as they have the adapters and know-how. only took 30 minutes to install mine. i paid $250 for the cdr-210. if the used unit has a scratched or worn (removable) faceplate, you can buy a new one at the porsche dealer for about $100. with a new face plate, the used radio will appear new.
I recently replaced the OE Alpine CD player in my car with a CDR-210. If you have the Hi-Fi sound package like my car you will have to have an adaptor cable made to connect the pre-amp outs to the OE harness. You also need the power connection adaptor. Call Becker (888) 423-3537 and ask for Burl in the parts department. <img src="graemlins/xyxwave.gif" border="0" alt="[bigbye]" />
Maverick
I just this weekend took an aftermarket radio out of my 95 993 and put an blaupunkt back in. I was very intimidated to start but it turned out to be very very easy. I would be glad to give you specific details about any part you have trouble with. You can email me at megmarc@aol.com or mmcglasson@bankofspringfield.com. Before you buy another wiring harness I would suggest you see what is already there. My after market radio that I took out was plugged directed into the original blaupunkt harness and they plugged directly into the back of my new radio. Please feel free to email with additional questions. MIck
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Thanks for everyone. The replies were so fast. I will check if my car still has original connector.
Maverick <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
