Tire rotational arrow
I just noticed the rotational arrow on my left front tire is pointing in the wrong direction. The front tires have approx 20K miles on them.. Should I be concerned?
I would be. (or at least your wife should be, if it's her car...
20k miles on them, installed as they are now? Were the tires perhaps rotated side-to-side? That would have them pointing the wrong way. Is the passenger side also pointing the wrong way? If not, then the wrong tire was ordered/installed on the left front (i.e., they ordered a right front for *both* fronts).
-Chris
-Chris
I think the one tire was mounted incorrectly on the wheel. I dont think they make a left tire and a right tire (correct me if im wrong)..Is the arrow there so you dont rotate the tires from side to side or is a tire designed to go in one direction only?
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
And as Mark in Baltimore suggests, you should have the tire remounted.
-Chris
Rennlist Hoonigan
which cost no drachmas
I would have them fix it, but most of the time in a radial tire the arrows are for the tread pattern, not the carcass of the tire. If you look at your tire, I'm sure you'll find that all the swipes and grooves are going in the wrong direction. You'll have horrible wet weather traction. Bias ply tires are another story all together.....
Matt
Matt
Another thing that is interesting is that the turbo twist wheels are not designated as left or right until you put your unidirectional wheels on them. Hard to explain.... but let me try. If you lay all of your wheels down you will see that the twist goes all in one direction. When you put them on the right side they will be rolling one direction and on the left side they will roll the other way. This can confuse some tire installers. If you have a targa you probably do not have turbo twists though.
