Tiptronic shift knob help
So I removed my shift **** to re-dye it. after install the **** moves up and down and won't stay in place. The shaft has a groove around it possibly for a split ring to lock the **** in place but I can't find any info on this either through an assembly drawing or part search. Any info would be greatly appreciated.
Not sure about tip, but the regular **** has a rubber insert that keeps the **** tight on the shaft. That is for the integrated boot/****. For the separate pieces, like rotwood ****, there's a set screw below the **** itself.
When putting it back on you had to make sure the edges lined up or you can round out the plastic edges on the ****.
