3 spoke steering wheel
Addict & Guru
[quote]Originally posted by pookee:
<strong>Do the splines line up the same on the 3 vs. 4 spoke wheels? If not, the car will require a front end alignment.</strong><hr></blockquote>
The consensus from past 3 spoke wheel swap threads is that an alignment will be needed to get the new wheel perfectly straight.
See, e.g.,
<a href="http://forums.rennlist.com/scripts/rennforums/ultimatebb.cgi?ubb=get_topic&f=3&t=001926" target="_blank">3-spoke steering wheel on 993? </a>
See, e.g.,
Basic Sponsor
Mark,
Proper alignment of the 3-spoke wheel on a 993 is not a matter of "missing a few teeth". The splines, although the same size, are positioned differently. Two splines can be used to achive the most centered look. One is too far to the right and the other is too far to the left (very slightly, it may not bother some) - there is not a right one. The car must be realigned for a perfect look.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
Try before you buy. I, too, thought I had to have the 996 three spoke wheel until I sat in a friend's new TT and actually spent a few minutes holding the wheel. My hands are a large glove size and I did not like the wheel because the stiching on the swollen parts of the wheel at 10 and 2 rubbed my fingers when holding the wheel in the 9 and 3 position I would use most often.
