What is cost to buy and install pss-9 ?
guys- im thinking of upgrading my suspension as well as lowing my 993c2 to ROW height.
What is the cost to get pss-9 kit, as well as the M030 kit w/ROW springs (in case i want to keep it OEM)?
Also, what should the cost of installation be? I was quoted $5k from my shop and I think that this is high.
thanks,
=r
thanks,
=r
You should take a look at <a href="http://www.carnewal.com" target="_blank">www.carnewal.com</a> and look in the suspension section.
For Pss9's with adj stab: $2595
5K for installation seems a bit high, unless they were going to include the costs of the parts as well. Even then, I spoke to some body who had the pss9's installed, and they said it cost about $1200 for installation. That should include installation, alignment, and corner balencing.
Jeff
Jeff
Lifetime Member
Lifetime Member
Standard installation time for all 4 shocks and springs shouldn't be no more than 4-6 hours even with sway bar change.
Factor in $125 (What the dealer charges here) labor for 4 wheel alignment. And maybe add 2 more hours for corner balance.
Note: The M030 setup can only be corner balanced in the front.
Rennlist Lifetime Member
I went through this within the last 6 months - I paid a bit less than $2595 for the full kit with RS adj sway bars; install with corner balance and full alignment was around $1000 (can't remember the exact amount).
I posted my "after thought" - see <a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=3&t=002211." target="_blank">http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=3&t=002211.</a>
Best of luck to you.
[quote]Originally posted by Robin 993 DX In Atlanta:
<strong>
Note: The M030 setup can only be corner balanced in the front.</strong><hr></blockquote>
True, but that’s usually enough. These cars are pretty close already. Mine was only a few pounds off, and some small tweaks on the front got it even closer.
<strong>
Hey Rob. EJ and I will do it for half of the shop's quoted price. Heck, for $2500, we'll even come up there to do it!
Seriously, though, what a ripoff quote. Are you sure they weren't quoting parts AND labor? Even then, it's kind of obscene.
To clarify, they were quoting $5k for parts and labor to install. Too much, right!?
John and EJ, you are both welcome to visit anytime... just bring your wrench.
I paid $1,699 for PSS-9's through Turner Motorsports, $275 for Euro M030 sway bars (non-adjustable but much stiffer than original) from Gert at Carnewal.com, and $1,000 for installation, corner balance, 4 wheel alignment and complete brake system flush (tossed in for good measure).
Total: $2,974 complete.
