Fault Code 26
Fault Code 26
Ok, got my new Durametric cable and tested the car today. Fault code is 26 oxygen sensing range 2 cyl (1-3). Can someone please explain this fault to me? For new users of these cables, after about 10 attempts to scan, I figured out that my car needed to be running to establish communications...
For me, I had to disable the immobilizer in order to establish a connection to the DME... Perhaps this link will help with the reported code.
https://rennlist.com/forums/993-foru...code-help.html
Attached is the factory document, I believe listing all the codes related to the 993:
It can be one or both of your oxygen sensors on the driver side of the engine is out of specification It may be the nomenclature "Area 2" above refers to the before or after catalytic converter specific oxygen sensor narrowing the problem down. Other Rennlisters may reply to your posting with the answer to this.
OR
You have something causing mixture problems on the driver side of the engine (Cylinders (1 through 3) only.
If the running data from each of the oxygen sensors seems reasonable the possible causes could be:
A vacuum leak as if it was an overall issue I would think it would impact both sides of the engine.
Sometimes an analysis of the oxygen sensors can seem inconclusive so if your oxygen sensors on that side of the engine have never been replaced I would just replace them both. No need to buy the Porsche branded part as BOSCH is the OE supplier and the aftermarket BOSCH branded part is the same part. It is an easy DIY. The key is to use a little penetrating oil on the sensor mount, cut the wires to it and slip a closed end box wrench over the sensor to crack it loose then fully screw in the new sensor in and then use the old sensor's cut wire to fish the new sensors pigtail up to its socket on the driver side engine compartment
wall.
Andy
- 26 Oxygen Sensing, Area 2 P1127 P1128 2 cylinders (1-3)
- P1127 = Version 3 Short to Ground / Below Lower Limit / Lean Mixture Limit
- P1128 = Version 4 Short to B+ / Above Upper Limit/ Rich Mixture Limit
- 2 Malfunction Indicator Light (MIL) is on and a previous Freeze Frame is overridden
OR
wall.
Andy
Thanks! tried pushing the Immobilizer button and even with the light off it wouldn’t communicate. I was just about to give up when I thought i’d Give it one shot with the engine running and it worked!
Andy
