Another weight reduction thread
in a quest for more power, i’ve come to the realization, as many of us have, that shorter gears and weight reduction would be the best route to take with these cars. I’d like to keep my car streetable and civil, i.e. maintain sound dentening, AC, heat, radio, sunroof and back seats. Want to keep the car safe too!! With that said, can I remove enough weight to make a difference?
thinking the following:
-RS door panels
- RS light-weight flywheel
- Rennline lower dash (are there safety issues remove the stock knee pad?)
-light weight exhaust - fister or GT3 setup
-ducktail or another glass deck lid
-light weight battery
what else?? Is it worth it?
-RS door panels
Rear wiper? And if You have AC get rid of the sun roof! It's really heavy and located at the worst place!
And what about Your own waist? Can You lose a few pounds there?
Saw a guy at a race last week who combined a beer belly with drilled pedals!
Suggest we start a new thread in this regard, as I wrote shortly ago.
Share your BMI, haha- Basal Metabolic Index, fairly accurate indicator of ideal body weight/adipose proportions.
Guarantee many will be surprised, as you do yourselves and the car the biggest favors.
https://www.nhlbi.nih.gov/health/edu...MI/bmicalc.htm
Weight reduction is definitely worth it, IMO.
I took over 200lbs out of the car pictured to the left and there were measurable gains in performance.
I'm 5' 9" 159lbs. Used to be 132lbs but looked like a skeleton so probably staying close to where I'm at.
Yes - gearing combined with some weight loss transforms this car!
RS clutch and flywheel is a great combination with gearing. I have the /21 gearbox which was standard RoW (or maybe just EMEA) but such a noticeable difference vs standard US gears.
I have no radio. Don't miss it even a little. Rear speakers out too (that weight is in the wrong spot).
I put the rear seats and seat belts back in. The kiddo sits back there. If the rear seats didn't get used I'd definitely remove the seats and seat belts.
Fister exhaust is definitely worth it on weight reduction (and sound).
I was surprised (shocked actually) how heavy the stock deck lid is. Fiberglass tail makes a big difference.
I haven't done the battery because it's in wrong place, and because I don't know how well it would work with the lightweight flywheel.
Good luck.
Good luck.
Easy option: lightest wheel/tire combo you can find. It's multiplied by 4, so a quick way to save a lot of weight.
Other plug and play options ideas (don't think these are very common, but worth exploring):
- side mirrors: Are there any plug and play options that are lighter than factory? This is common in the racing world.
- manual window backdate? Window motors are heavy. I'd have to think there's a path to add a manual regulator
Hard stuff: Remove unused wiring.
- If you don't need power windows, power seats, heated seats, radio, speakers, amps, antennas, (maybe immobilizer), sunroof then you don't need a of wiring / fuses / relays. You can thin your harness. I just did this and it's a ton of work. It saved me 30 lbs on my race car so was well worth it. Obviously cost/benefit would need to be explored as this is far from plug and play and again, is a lot of work.
I just lost 55lbs by switching out the standard 8 way seats to Recaro Pole Positions.
It’s slippery slope for sure...I’m at 2683lbs with 1/2 tank and no driver and that’s still with the 53lb sunroof gear up top (that’s next). I have line of sight to 2595lbs 1/2 tank no driver (I already have the full regear) and let me tell you...the secret to speed is low weight (so said Walter Rohrl)
What part of the sunroof is 53 pounds? That sounds 10X high.
There is no cheap/easy way to lighten a 993. Almost everything is a battle over a couple of pounds here and there. I once had my car down to 2850 pounds, and it was noticeable. But not noticeable enough. If you did race buckets, lighter battery, FG hood, RS flywheel, short gears, and flash the ECU, you'll have a really fun car. Probably 125 pounds lighter with better gearing and a tiny bit more power. But a 993 will never be fast in the way a 991 is fast, but a 991 will never have the character and personality of a 993.
net difference for mine was 54#
The unsprung rotating mass in the form of wheels and tires, pays performance as well as weight dividends far beyond the understanding of most (not all), RL 993 owners...
I get a good chuckle out of those that have no understanding and poo-poo these simple, yet well established laws of physics.
+993!!!
