993 Forum 1995-1998
Central Warning Light (!)
Old Aug 15, 2018 | 06:05 PM
DM993tt's Avatar
DM993tt
Default Central Warning Light (!)
I have had the central warning light on my car lit since an engine rebuild & reprogram. The switch in the console does nothing to make the big red exclamation point on the gauge go away. Any thoughts or suggestions or ideas on what is causing the issue or how to diagnose? thanks.
Old Aug 16, 2018 | 12:20 AM
Greg Bell's Avatar
Greg Bell
Check the electrical connections inside the back of your handbrake handle. A copper clip can come loose causing the red light to stay on - an easy fix if that is what it is.
Old Aug 16, 2018 | 02:19 AM
ToreB's Avatar
ToreB
I would guess one other warning light is either blown or removed. I would start checking with the airbag warning lamp in the clock.
Cheers,
Tore
