993 Forum 1995-1998
993 Engine idling problem
Old Aug 6, 2018 | 12:28 AM
EVANpo's Avatar
EVANpo
Default 993 Engine idling problem
hi
Today i launch engine~~~Feeling very good!!!
After the engine reaches the working temperature, stop the engine....
Start the engine again and start to have problems.
But step on the gas pedal the engine idling in 2000 rpm not down,i shall ISV signal connector removal,engine speed returns to normal......
Report with everyone....
I already replaced...TPS、ISV、MFA、Vacuum hose.
Is there a way to solve the problem of engine idling?
Old Aug 6, 2018 | 08:25 AM
Gbos1's Avatar
Gbos1
Check your throttle cable. It could have popped out of the rubber grommet on underside of car. Hard to get to and a real B*tch to get back in!
Old Aug 6, 2018 | 11:57 AM
pp000830's Avatar
pp000830
+1, also check peddle cluster that gas peddle is fully returning to up position when foot is off the gas.
Old Aug 6, 2018 | 07:06 PM
Railmaster.'s Avatar
Railmaster.
The pedal was My first idea too!
Old Aug 6, 2018 | 10:12 PM
EVANpo's Avatar
EVANpo
Thank you Gbos1、pp000830
I will report the test results......
Old Aug 7, 2018 | 06:00 AM
EVANpo's Avatar
EVANpo
Today i tested it....
Starting the engine again seems to be normal..
But the air-conditioning is on, the engine idling is more exaggerated.
I also tried to disconnect the battery for more than 30 minutes and let the ECU relearn.
Unfortunately, it did not succeed........
Such an engine idling makes it a headache....
