A/C drops RPM every 20-30 sec
Hi Guys,
Do you guys notice that while turning on the A/C the power drops and the car pull back slghtly every 30 sec or so.
I notice the RPM drops slight when stationart and also driving.
Is this normal?
_Kadeer
1995 993 C2
Is this normal?
_Kadeer
1995 993 C2
Kadeer:
In addition to Sean's suggestion, you might have the freon charged checked. If the charge pressure is too low, the low freon control switch causes the compressor to cycle off.
Good luck ! These A/C issues are a bi$%h !
Regards
Regards
