993 Forum 1995-1998
Introduction: Motul
Old 06-29-2018, 05:39 PM
  #46
Ipe
Ipe's Avatar
Very interested on this. I use Mobil 1 V-Twin on my both 993s and I have to import them as they are not available here. Motul otherwise have all its line here available. I understand that 4100 is not even 100% synthetic, is that right?
Old 06-30-2018, 10:35 AM
  #47
CaptainGSR
CaptainGSR's Avatar
+1 for the Motul 15w50 300v Competition
I switched from Mobil 1 to Motul when i moved to France 4 years ago.
I also use RBF600 in all my cars.
Old 06-30-2018, 11:04 AM
  #48
niche
niche's Avatar
Great oil
I use Motul 5/40 x-cess on watercooler and
Mobil 1 v-twin 20/50 on aircolled
Old 06-30-2018, 02:44 PM
  #49
bw993
bw993's Avatar
I found some Dynamic Wear Test data under load on the oils discussed in this tread. Apparently, this test measures the oil’s capacity to sustain stress under load at 230 (F) and quantifies it in PSI. Just sharing what I found on another motor oil information site.
105,000 to 120,000 psi = INCREDIBLE wear protection.
90,000 to 105,000 psi = OUTSTANDING wear protection.
75,000 to 90,000 psi = GOOD wear protection
0W40 Mobil 1 “FS” European Car Formula, ACEA A3/B3, A3/B4, API SN, synthetic = 127,221 psi
5W30 Motul 300V Ester Core 4T Racing Oil, synthetic = 112,464 psi
10W30 Amsoil Dominator Racing Oil synthetic = 97,118 psi
10W40 Mobil 1 Racing 4T, four stroke Motorcycle oil, synthetic = 93,661 psi
5W50 Mobil 1, API SN, synthetic = 86,456 psi
20W50 Royal Purple API SN synthetic = 83,487 psi
Brad Penn, Penn Grade 1 Nitro 70 Racing Oil semi-synthetic = 72,003 psi
15W50 Mobil 1, API SN synthetic = 70,235 psi
Old 07-02-2018, 08:17 AM
  #51
964Lovac
964Lovac's Avatar
Quick question- Looking at 300v 15-50 and only finding the motorcycle one for sale- what's the difference between the two and where can I purchase?
Thanks!
Old 11-03-2018, 03:15 PM
  #53
k722070
k722070's Avatar
here's a motul 300v competition, 1st column, vs mobil 1, 2nd column
both 15w50 used in the same engine for 8.5 track days each, no street miles.
there was zero noticeable difference between the oils when driving the car.
the big difference is motul is 3x more expensive retail, 7x more expensive if using the mobil rebate.
motul has more molybdenum and calcium, mobil uses more boron and magnesium, just different additive strategies.
the calcium is interesting, does this mean motul uses more detergent?
viscosity is similar and within range so both oils were still protecting and could be used for longer intervals.
we could speculate and say since iron and lead show up smaller in the motul sample it was protecting better,
but the amount of iron and lead in both samples is very small and probably not worth even a mention.
there is nothing robust about this test on a single engine and with only one sample,
it is just posted for the curious.
Old 11-03-2018, 03:33 PM
  #54
k722070
k722070's Avatar
just reading articles on the silicon(dust), 6ppm motul vs 3ppm mobil.
best guess from the increase would be damaged air filter or contaminated sample.
but how about this, if the higher calcium in motul means more detergent, maybe more detergent suspended more contaminants?
in that case motul is better because it removes potentially damaging particles from the engine.
only a guess.
Old 12-05-2018, 10:00 AM
  #55
Virob
8th Gear
Virob's Avatar
Is it safe to say that this thread is dead and no official numbers will be forthcoming from Motul on zinc/phosphorus levels in their oils?
Old 12-05-2018, 04:32 PM
  #57
Chuck W.
Chuck W.'s Avatar
Originally Posted by Motul
If you have any questions on why that is, feel free to drop a line here. -Nick
Nick.... are we looking at 104244 for our 993s? TIA
Old 12-05-2018, 04:38 PM
  #58
JasonAndreas
Technical Guru
JasonAndreas's Avatar
we're trying to change the conversation of "more ZDDP= better" as many factors contribute to a good oil formulation;
It seems the response from PAG to the camshaft issues (corrosion) on all of their hardly-ever-driven-models (especially the CGT) was to specify on their branded oils a calcium level 3x (now similar to yours) some boutique oils like Brad Penn and leaving the ZDDP levels as-is.
Old 12-06-2018, 01:38 PM
  #60
Andy Hodapp
Andy Hodapp's Avatar
Just ordered some 4100 15W50, thought I would change things up from Brad Penn. Hope it performs well.
Quick Reply: Introduction: Motul
