993 Forum 1995-1998
Fan Housing Refinishing
Old Jun 3, 2018 | 10:00 AM
dommorton's Avatar
dommorton
Default Fan Housing Refinishing
Hi from the UK
I wonder if you can help me please.
I've had the fan housing for my '98 C4S vapour blasted along with a bunch of other engine and HVAC components. They have all come up lovely and shiny as new, so I would like to keep them that way if possible without them turning in to a corroded mess.
I've coated the alloy air tube, air diverters, a/c compressor and a/c pedestal, with ACF-50. Not sure if you have that in the US? Its a corrosion inhibitor for metals as used on planes and now more commonly motorcycles to prevent corrosion of alloy parts. This should keep them fresh for some time to come and I can apply more to the visible parts once on the car if required. When it comes to the fan housing however I am not so sure on the route to take. I want it to be factory finish or as close to and it currently looks great freshly vapour blasted. I'm just concerned that the coating of ACF may not be enough longer term, as getting to the part to maintain it will be hard once back on the car.
I understand the part is a magnesium alloy (don't know if anyone can confirm?) and with that painting can be difficult as the mag can gas and push the paint off. Also this isn't the factory finish.
Does anyone know if any coating was used by Porsche from new? Or if you have any advice on how best to tackle the refinishing of this part to keep it looking fresh please do share.
Old Jun 3, 2018 | 12:53 PM
samurai_k's Avatar
samurai_k
Can you annodize it?
Old Jun 3, 2018 | 01:08 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Find a local shop that can apply Cerakote.
Old Jun 4, 2018 | 11:10 AM
Super90's Avatar
Super90
Already was down this path...
https://rennlist.com/forums/964-foru...ry-finish.html
The black chromate was supposedly treated with Tectyl (a corrosion preventative made by Valvoline) at the factory. I'm reading that was the process for quite some time and there are some friends that restore the early cars that have dealt with this too. Tectyl seems to be difficult to source in the U.S. now. I'm finding out via some sources that using another "oils" produces good results. The PO of my car, who does lots of restoration projects for himself, likes to use Gibbs Penetrating Oil on such magnesium parts. I had read about people using it on old "hot rods" on the mag wheels to give the nice dark gray patina.
Interestingly, this black chromated magnesium part is a bit of Porsche history.
I used the Gibbs Oil on my fan housing and it's doing well. I did not have it media blasted beforehand though....
R.
Old Jun 4, 2018 | 11:27 AM
Tuner1's Avatar
Tuner1
That is what I did. Excellent results!
Old Jun 4, 2018 | 01:13 PM
dommorton's Avatar
dommorton
Very interesting thank you.
So do we think the current silver finish I have here post Vapour Blasting is as per new but at the factory they applied a corosion inhibiting oil that turns the part that distinctive grey?
So perhaps ACF-50 will be fine, or I need to find some of this Tectyl and DIY to get it to factory appearance and durability.
Old Jun 4, 2018 | 02:38 PM
JasonAndreas
Technical Guru
Tectyl (i don't think I have ever seen on a 964/993 fan...) needs to be reapplied every 12 months (per Porsche) and ACF-50 has a 24 month lifespan. You need something more permanent over the bare vapour blasted metal.
Old Jun 4, 2018 | 02:50 PM
dommorton's Avatar
dommorton
Is the factory finish bright silver like my blasted part, or are they chromate coated then something over the top of that from factory? I understand from online reading that black chromate isn’t a corrosion inhibitor in its own right and usually just forms the base prep coat.
Old Jun 4, 2018 | 04:49 PM
paulkromz's Avatar
paulkromz
pics please
Old Jun 4, 2018 | 04:54 PM
Spyerx's Avatar
Spyerx
On my 964 we vapor blasted and then PVD coated the fan and housing.
On my 89 carrera we vapor blasted and just clear-coated them to keep the natural look.
This is my 964 fan:
Old Jun 4, 2018 | 05:14 PM
dommorton's Avatar
dommorton
That looks smart, but as you say it isn't natural. I want the appearance as close to factory as possible really.
So with clear coat, you just sprayed regular clear on to the bare mag? I presume it's held up ok
Old Jun 4, 2018 | 06:08 PM
Spyerx's Avatar
Spyerx
I'm not exactly sure what exact paint they used, but it's held up fine since the year I had it done. You can see the results below. When we blasted the metal this is what it looked like, and we just cleared it in.
Old Jun 4, 2018 | 06:15 PM
Super90's Avatar
Super90
Natural....
dommorton's Avatar
dommorton
Basically how mine looks now then.
Ok so clear coat may be an option. Thanks for sharing.
Old Jun 4, 2018 | 06:16 PM
dommorton's Avatar
dommorton
Originally Posted by Super90
Natural....
Ah ok now that is how I figure it should look and would like to replicate.
Is this just a chromate finish?
