Airbag bypass bridge
This thread was on the 964 forum. Does anyone know if this plug is present on a 95 993? I removed that carpet door and there is no bracket and no wires or plug to be found. Felt all around and used a mirror. Should I remove the the center console and keep looking or did they delete the plug in the 993
The part number is 928 612 220 00
![](https://img.photobucket.com/albums/v483/jpar/911/20140218_203705_zpsua9wmvoo.jpg)
First remove the two philips screws on the small access panel on the passenger side of the center console, the undo the 8mm bolt
![](https://img.photobucket.com/albums/v483/jpar/911/20140218_203836_zpsye7e1jax.jpg)
Next unplug the connetor
![](https://img.photobucket.com/albums/v483/jpar/911/20140218_203545_zpsymyvt7r4.jpg)
lastly plug the bridge in and snap the plug back onto the bracket and re-install.
![](https://img.photobucket.com/albums/v483/jpar/911/20140218_203601_zpsnwfckobd.jpg)
