993 Forum 1995-1998
Sick speedometer
Old Mar 31, 2018 | 08:01 PM
RudyP's Avatar
RudyP
Default Sick speedometer
A few days ago when I was driving down the highway, the speedometer in my 96 C4S just dropped from 65mph down to zero. After a brief check that I had not driven head on into a bridge abutment, I confirmed the speedo (and odometer) were not working. On the drive home that night it magically worked again so I hoped that maybe it was a fluke. Unfortunately, the issue recurred today and again the speedo went to zero as I was driving. Despite the dubious benefits of a car that no longer ages (at least in terms of miles) and a potential solid gold excuse for the CHP should I get pulled over for speeding, I’d really like to get it fixed. Any wisdom from the more mechanically inclined rennlisters? Any ideas whether the issue is in the gauge (internal gears?), wiring or wherever the sensor might be that sends the signal to the gauge? I will take it to my local air cooled independent mechanic but if this is a common issue with a known fix, perhaps I can shortcut the process (eg just send the gauge to Palo Alto Speedometer?)
Thanks in advance!
Old Mar 31, 2018 | 08:35 PM
nine9six's Avatar
nine9six
It sounds as if your speedo has broken the nylon gear inside... this happens with the age of our cars, and has been discussed many, many times in the past.
If you do a Google search on "broken Porsche speedometer gear", you will find several DIY fixes, along with a link to: http://www.odometergears.com/product...1-993+94-98/72
Here ia link to the DIY that I followed...
Hope this helps...
Old Mar 31, 2018 | 09:03 PM
fsa's Avatar
fsa
If you opt to not do it yourself, as I did when my odometer failed, I sent to a very experienced gauge repair person, a fellow Rennlister below. He did a fantastic job, turned the item around immediately, and the price was very fair. My bulbs were also replaced.
CalvinC4S
Old Mar 31, 2018 | 09:11 PM
RudyP's Avatar
RudyP
Thanks guys. I figured it might be that as I have read about the odometer gear repairs on here but I wasn't certain since all the threads I found mentioned odometer but not speedometer failure also. So I wasn't sure if that was the same failure - the speedometer going to zero is much more obvious than the odometer not clicking up so it seemed odd that it was always odometer and not speedometer that was mentioned but they are obviously related.
Thanks again!
Old Apr 1, 2018 | 03:11 AM
Greg Bell's Avatar
Greg Bell
Check the fuses in the front under the bonnet, not sure which one. After having some work done some time back the speedo wouldn't work. Someone more knowledgable than me went straight to the fuse box and pulled the offending fuse. Worth a look anyway.
Old Apr 1, 2018 | 08:48 AM
knorrena's Avatar
knorrena
The odometer gear failing does not affect the speedometer, If it is indeed your speedometer giving you issue, I would ignore the "change you odometer gear" advice you got. The speedometers in our cars don't use gears to indicate speed. The speed signal is driven by the DME, so you likely have one of these issues: 1) bad wiring; 2) bad connector; 3) bad fuse; 4) or a faulty speedometer. If its intermittent as you say, its likely issue 1 or 2.
Old Apr 1, 2018 | 02:52 PM
ToreB's Avatar
ToreB
This is not the odometer gear, I would expect this to be caused by intermittent contact on the speedo connector. This is a commonly seen problem.
You could take out the instrument, (it just pulls out of the dash) and disconnect/connect the main harness connector some times. This will remove any corrosion on the pins.
You could of course use some electronics contact cleaner as well, but don't use a lot, and do not fill the fluid into the instrument.
Cheers,
Tore
Old Apr 1, 2018 | 03:12 PM
nine9six's Avatar
nine9six
Thanks in advance!
When my gear broke, I had no speedometer and no odometer. When I bought a new gear and replaced it, both the speedo and odometer once again functioned. The sudden non-functioning speedo stuck out like a sore thumb, caught my attention, and was the catalyst for my investigation into the problem and solution.
This is despite the speedo signal originating at a sensor at the front wheel, and the electric motor contained within the speedometer...Could the speedo be electro-mechanically driven?
https://rennlist.com/forums/996-foru...ed-sensor.html
... I have been wrong before.
The OP can always choose to "ignore" a non-functioning odometer, as Karl suggests above, but if you were ever to sell your car and there was ever a question as to the authenticity of the mileage, and someone stumbled upon this post, you might have some, "esplainin to do Lucy"
7 Porsche Models That Have Aged Like Fine Wine
Old Apr 1, 2018 | 04:41 PM
RudyP's Avatar
RudyP
I am definitely not planning on leaving it broken. In fact, I am avoiding driving it until I fix it because I dont want the real mileage and the depicted mileage to diverge (about 11 miles so far by my estimate). It's not so much for resale reasons but it bugs my OCD tendencies...
Old Apr 3, 2018 | 07:19 PM
bcgreen's Avatar
bcgreen
CalvinC4S
Send me a pm on who helped with the repair.
Old Apr 5, 2018 | 12:52 PM
RudyP's Avatar
RudyP
It’s right there in his post you quoted: CalvinC4S
He wasn’t signing his name.
Old Apr 5, 2018 | 01:03 PM
bcgreen's Avatar
bcgreen
Old Apr 6, 2018 | 05:07 PM
knorrena's Avatar
knorrena
nine9six,
You really should read more closely. I did not suggest that the OP ignore a broken odometer or a broken speedometer. That would be unethical.
Old Apr 12, 2018 | 08:54 PM
RudyP's Avatar
RudyP
For anyone (present or future) who is curious about the resolution of my speedo issue - it was a failure of the internal speedometer drive gears which required overhaul of the speedometer gauge/unit. They also replaced the odometer gears (the more common failure) while they were in there already. Everything is working again now.
Old Apr 12, 2018 | 11:28 PM
fsa's Avatar
fsa
Good news.Very expeditious in time.
Who did the repair?
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
