Silver big brake calipers, are they real/original? & what to service?
Basic Sponsor
A little trick you may want to use when putting new dust boots in is to utilize hairspray. Get a q-tip and put a small amount of hairspray around the edges of the dust boot. It will pop right in!
High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
Sorry, it took a while (lot's of travel). I did measure the piston sizes yesterday
Front: 44mm and 36mm
Rear: 28mm both
So I assume these are indeed Turbo calipers, and I don't believe they have been painted before.
Looking at the condition of the calipers, I will only change the inner-seals and dust-covers, the pistons look fine.
Thanks for all the comments and advice
The faces of those front caliper pistons look hammered to me and will not apply even pressure to the backs of the brake pads without needlessly distorting the internal piston seals...
Admittedly, the business portion of the pistons is the O.D. for hydraulic sealing purposes, but under optimal conditions, the faces should be perpendicular to the OD of the pistons.
...I'd replace the front pistons.
Hi nine9six, thanks for your comments, the caliper pistons were not cleaned when taking these pictures, over the weekend when I am back, I will clean all of them and post some better pictures. cheers!
Basic Sponsor
Great project and learning experiment!
Hi, as usual it took a little longer......
Here some pics from the pistons.... some small blemishes on the tops (when you feel you can hardly notice). Cylinder walls look great, as do the bottoms. Appreciate any comment, thanks
ps, bought a set of seals and boots from Ohio Performance solutions, great service and communication, help in shipping to EU. Thanks Steph, will update how the rebuild goes!
When bleeding the calipers at installation be sure to tap the calipers to shake loose any air bells sticking to the inside of the caliper castings. This can save you a redo.
Basic Sponsor
Excellent! Now get back to work so we can see the finished product!
So....it took a few months to give an update, but, the actual work was done within an evening.
I am very happy with the result, thank you all for the advice and tips, it went great!!
