993 Forum 1995-1998
Source for vinyl stone guards
Old Mar 4, 2002 | 07:36 PM
Buck's Avatar
Buck
Post Source for vinyl stone guards
Any recommendations on a source for the vinyl stone guards that go behind the doors and the backside of the front and rear wheel openings?
Thanks!
Old Mar 4, 2002 | 07:48 PM
Richard C2S's Avatar
Richard C2S
Post
Buck,
A couple of body shops have mentioned that they get the stone guard material from the dealer and that it is a bitch to put them on cleanly.
Richard (not C4S)
Old Mar 4, 2002 | 07:56 PM
KC993's Avatar
KC993
Post
Well guys,
From what I have heard, they are a bitch to peel off and clean the area. But they go on like a piece of tinted window film only smaller and thicker.
Old Mar 4, 2002 | 08:20 PM
tom_993's Avatar
tom_993
Post
I got a set from the old Automotion. They aren’t TOO hard to install. Just clean the area really well, then generously spray a lubricant (I think I used a window cleaner) over the entire area. Position them, squeegee out the bubbles, and then let dry.
Old Mar 4, 2002 | 11:21 PM
c4-toy's Avatar
c4-toy
Post
Bought a set last fall from Performance Products. Made by 3M and are the same that the dealership sells (but for less $$, i know i saw them there had the same peel-off backing). If i remember correctly it was $99.00 for both.
Now all i need to do is get enough guts to put them on my 96 C4 Cab, it is NOT an easy task. Good luck!
Old Mar 4, 2002 | 11:52 PM
E. J. - 993 Alumni's Avatar
E. J. - 993 Alumni
Post
If you just want to do the rear wheel arches, just buy the material from 3M or a distributor and then trace the shape of the existing ones on your car. Use an exacto knife to cut them to match. Then use a hair dryer to warm up the old ones and peel them off. Then clean the surface really well, spray on a mixture of alchohol (sp?) and water from a spray bottle on both the car and the back of the sticker (spray a lot) and then place the stickers and squeege out the liquid. After a few days all the bubbles will go away and you saved yourself some bucks. If you don't want to do it, call a window tinting place and let them do it for you.
Good luck,
E. J.
Old Mar 5, 2002 | 02:44 AM
ken garchow's Avatar
ken garchow
Post
my 98S has some type of rear fender protection, but it looks to be colored, kinda matches the body color, are these factory?
Old Mar 5, 2002 | 09:09 AM
Buck's Avatar
Buck
Post
I've looked at several suppliers and found the the pieces that go in front of the rear fenders but not the wheel arches. I've also not been able to find either in White. I can only find clear. Didn't I read not too long ago that because of yellowing there are white ones for white cars?
Old Mar 5, 2002 | 01:08 PM
E. J. - 993 Alumni
Post
AFAIK, white ones are only available from the dealer. Same stuff, just colored.
E. J.
Old Mar 5, 2002 | 01:22 PM
Ray Calvo's Avatar
Ray Calvo
Passed On
Smile
RE ones just in front of the rear wheels - buy the ones for '96 and later cars. They're larger and give better protection. Do an archive search; I described how I removed old ones and installed new ones (royal PITA).
I know of no factory ones on backside of front and rear wheel arches. I had extra material left over from when a local company installed the 3M nose bra ("Invisishield"); I cut my own to fit along the rear of the F&R wheel arch cutouts and slapped them in.
