Why don't 993 rear wheels sit in the middle of the arches?
Hunting for a 993 has me looking at *many* pictures. Obviously, the rear and silhouette looks incredible, but one thing throws me off: The rear wheels, when looked at from the side, do not sit in the middle of the wheel arches, but slightly shifted to the front of the car. Why is this and why isn't anyone bothered by this? Please note the picture of the turbo, where this doesn't seem to be the case. I am so confused..
Good question. I am sure the engineers had a reason. The front is the same I believe, not dead center.
The further forward the less caster ie the less KT.
The less KT or caster the twitchier, faster reacting the rear will be
Could the engine of the Turbo sitting 40mm (~ 1.5") further back in the car be a factor as well?
Mine look centered. It's lowered.
E30M3, I am not sure that's super centered, both wheels look a little forward to me.
Bill's is a great case in point, as you obviously know what you're doing and still have them sit forward.
Awesome, thank you guys. I will need to learn what those KT angles mean now. Not a clue
Together they articulate around an axis called the instant axis, the dash-dot inclined line seen here
The geometry and nature of the connections, particularly the soft joint at the inner end on #5 determines the camber and toe curves
The arms are in 2 planes, when extended they meet at the longitudinal instant center
Alfa40 (07-11-2019)
