95-96 vs 97+ Door Card Insert Compatibility
I'd like to convert my all gray door cards to the two-tone (black & gray) 97+ style. This photo that was posted by Zeus993 (thanks) shows what I'm trying to describe. The insert is wider compared to the 95-96 version, closing the gap between the insert and the armrest.
Does anyone know if the wider 97+ insert can be installed on the 95-96 door cards?
That extra gap is likely caused by failing door pocket attachments. See this thread for the repair - it tightened mine right up. No more sinking arm rest. https://rennlist.com/forums/993-foru...forcement.html
I've just done this with my car. I retrimmed the classic grey back section a few months ago and the replaced the insert with a carbon fibre piece last weekend.
The original insert was held in place with about 10 clips, but the carbon uses a rail. I had to transfer the rail onto my cards. You can see the holes I cut for the clips in this picture.
And installed . . .
I'm not sure if the later series inserts use the same clips as earlier models, but obviously the CF pieces need the rails.
And installed . . .
The original insert was held in place with about 10 clips, but the carbon uses a rail. I had to transfer the rail onto my cards. You can see the holes I cut for the rail.
If I understand correctly, you had to make holes in the door card to connect the rail to the card using clips. How does the insert connect to the rail? Is the rail the only thing that attaches the insert to the card?
The rails are riveted into place on the door card. There is a rail on both the card and the trim piece. You slide the trim down the rail to install it.
Donor door:
I used baking paper to make a template for the holes
Donor door:
YDG is right --- the 97 door cards use a rail system to mount the inserts, whereas the 95/96 door cards use a tab system. It is easiest to just find 97 door cards. Also, do note that some of plastic mounting points on the 97 door cards are different thicknesses as compared to the 95/96 door cards. I suspect Porsche did this for durability reasons. This will necessitate longer mounting hardware. I have BTDT ---- learn from my agonies. :-) I wrote about it here: https://rennlist.com/forums/993-foru...l#post13507866
I'll post pictures and details if/when I manage to find all of the parts. I was hoping I could mount the new inserts on my cards; but, the rail mounting system means that I will have to find a complete set of door cards at a reasonable cost.
And installed . . .
And installed . . .
This is really well done. Bravo Adding black in this area (door panel middle part) in an otherwise entirely class-grey interior I think it one of the best ways to un-grey-ify the interior. This is because black here is aesthetically logically --- it continues the black band on the dash into the doors. Otherwise, the interior is a sea of classic grey, which sometimes turns purplish over time.
Thanks for the additional details, JLAA. Your interior came out great, the green provides a nice level of contrast.
Thanks. You can technically rivet the rail onto your old door panel, but I bet it would be super difficult to find the rail as a separate part.
You could hypothetically source a set of 97 door panels in really rough condition for the rail, but at that point, then instead of harvesting the rail and destroying the set of door panels, you could spend a few clams and get the 97 middle door panel recovered and then sell the 95/96 door panels to recoup costs.
I noticed your current interior is classic grey (as was mine). What color scheme are you going for w/ your mini project?
I was trying to keep the grey theme but just tone it done a little bit. This the result ---- I switched the inner door panel to black, and then used the bigger 97 door panel insert covered in grey to make sure that there wasn't too much black. Note that I think the HiFi door panel speaker pockets, which I added, introduces textural contrast (carpet) and in grey color, conspires to frame the black in limited, accent quantities.
As you noted, the mounting rails are not available separately, so my only option is to buy a complete set of 97+ door panels and have them recovered. So far, the only set that I've found are on Ebay at about $800 for the pair, which is more than I want to spend for donor parts. I'd like to find a more beat-up set of panels at a lower price, since the panels will be recovered and I can reuse my existing parts to the maximum extent possible.
I agree that the HiFi style door bins do a great job of "connecting" the gray knee pad to the gray section of the door panel, its a good look. Having said that, I plan to stay with my non-HiFi door bins because they are in almost perfect condition.
