Some years back I mounted some led lights which I got from Gert to replace my fog lights. However, they are really small and weak. Does anyone know where you can order some good led lights? Thanks
I modified the ones from Gert to give both driving and parking lights. Some fiddling with the fog circuit was required ref Canadian cars. The leds were driving off ebay and parking from Tore.
Reason: grammar
But that light is for the Turbo S scoop not for the standard 993.
If it's the std H3 for std fog, then the leds available work better as a driving lamp and don't illuminate the road very well. You can get Hids to work but it requires some modifying to the unit. I use 30watt leds in the Fogs on the 944 as driving lights with leds in the headlights but they are quite bulky and will not fit the 993 fog housing. If you fit Tore's Hids in the dip, fogs are superfluous.
You need to buy the ones with the most leds in them then so they spread the light, the early ones where just a single pen light looking affair, something more like;
This lighting housing looks just like mine (previous owner had installed these, I wasn't sure what type of air scoops they were) I'm waiting for some 36mm festoon error free LED bulbs to see if they will be brighter than existing bulbs.
