993 Forum 1995-1998
Front Control Arm Bushing Options
Old Sep 19, 2017 | 02:58 PM
GBX's Avatar
GBX
Default Front Control Arm Bushing Options
Getting ready to replace my control arm bushings and notice that rubber bushings are available from Elephant, Rennline, ERP, FVD, etc and all at different prices. Are they all the same? They look identical and i wont if they're all sourced from the same manufacturer? Any recommendations?
Old Sep 19, 2017 | 03:42 PM
goofballdeluxe's Avatar
goofballdeluxe
I'd go with Walrod bushings. Highly recommended, and I've never ever heard anyone have any problems.
Source at FDM Motorsports. About $100 and change I think.
Old Sep 19, 2017 | 04:04 PM
Spyder_Man's Avatar
Spyder_Man
If you want to replace more of your bushings for a complete overhaul, then I'd look into the "sport" Elephant Racing bushings.
If you just want to address the front end, then Walrod.
Old Sep 19, 2017 | 04:14 PM
Tlaloc75's Avatar
Tlaloc75
I have experience with both Elephant and FVD. They are different manufacturers, as far as I can tell, but the quality seems equivalent and they are both good choices. I personally used Elephant for all my control arm bushings and FVD for my subframe bushings.
Old Sep 19, 2017 | 04:28 PM
AOW162435's Avatar
AOW162435
Seared
Jason,
I've rebuilt dozens of sets of 993 control arms over the last 10 years or so. Most of these have been with Walrod polyurethane bushings. Over the last two years I've also rebuilt 7 or 8 sets using Elephant bushings.
My only experience is with Walrod bushings - I installed a set on my clunker shortly after Chris developed them and have no complaints whatsoever.
Rebuilt arms with Elephant bushings:
Rebuilt arms with Walrod bushings:
Andreas
Old Sep 19, 2017 | 06:14 PM
Dr. No's Avatar
Dr. No
^^^Almost a shame to put those back in a car where they're going to get all dirty.^^^
Very nice work.
I forget - is there any ongoing maintenance (lubrication) required by going to one of the non-OEM bushings?
Old Sep 21, 2017 | 02:06 AM
akrca4's Avatar
akrca4
I had rebuilt arms with walrod from Andreas and love it!
Old Sep 21, 2017 | 02:24 AM
nine9six's Avatar
nine9six
Originally Posted by AOW162435
Jason,
Andreas
Andreas,
May I ask what finish is on the ctrl arms with the walrod bushes?
Those are sanitary beyond words!
Old Sep 21, 2017 | 08:57 AM
AOW162435's Avatar
AOW162435
Seared
Originally Posted by nine9six
Andreas,
After removing the original bushings & sleeves, I media blast the arms clean. Then I wash them thoroughly using a prep solvent before installing the new bushings. Once re-bushed, I wipe the arms down with a proprietary lubricant that contains a blend of aliphatic hydrocarbons and mineral oils.
Andreas
Old Sep 21, 2017 | 09:14 AM
s14kev's Avatar
s14kev
Andreas
Looks like you media blast the sleeves also. They should be cad or yellow zinc plated before install. Installed as you have shown, the raw steel will surface rust and look terrible in a few weeks. Here's a set that I did previously
File Type: jpg
Old Sep 21, 2017 | 09:21 AM
AOW162435's Avatar
AOW162435
Seared
Those look great.
Andreas
Old Sep 22, 2017 | 01:37 AM
samurai_k's Avatar
samurai_k
I just had Chuck at elephant racing down in Santa Clara install his sport bushings into my cleaned control arms for a nominal service charge. I went down there as he said he could check out my control arm ball joints and my rear toe control arms I just pulled off my car. Well worth the visit as he showed me what a good set felt like and behaves.
Dropped off before lunch, came back after lunch with the bushings perfectly installed along with some new ball joints, and a new pair of toe control arms shipped my house.
Going in tonight!
File Type: jpg
Old Sep 22, 2017 | 03:39 AM
MarinS4's Avatar
MarinS4
I was thinking the same thing.
I only polished the inner sleeve and left the outer zinc coating alone. I also have a spare set that I plan to chrome plate for maximum slippery surface.
Old Sep 27, 2017 | 05:24 PM
AOW162435's Avatar
AOW162435
Seared
Like this? Just picked my batch of sleeves up from a 'local' plater today:
Andreas
Old Sep 27, 2017 | 06:33 PM
OverBoosted28's Avatar
OverBoosted28
Andreas
Deeyaammmm!!!!! :-)
