Clutch cylinder? / Gear selection
This morning when i went to drive the car, i found it impossible to select any gear. I dipped the clutch a couple of times, then got it into 6th, and then into reverse, so as to move off out of the driveway. Then, as i moved the lever out of reverse to head forwards in first, the same thing happened - no selection. So I put the car away.
Never had a problem like this before, and the clutch and plate are only a year and 8k miles old. I'm pretty light on clutches too, over the years.
Could this be a failing master or slave cylinder?
