SmartTOP install
Old Jan 5, 2026 | 07:40 PM
Guzzgreg's Avatar
Guzzgreg
Yes I very much appreciate what Martin did and expressed my thanks Read post 11. It was incredibly helpful in getting everything unplugged. Again THANK YOU Martin.
So Again OTHER than the update, do I have to configure the module AFTER the update confirmation or can I just unplug from my computer and plug it into my car. That is the basic question I'm asking.
Old Jan 5, 2026 | 08:00 PM
ctzn's Avatar
ctzn
I don't really have any interest in installing the SmartTOP, kinda lame that US regulations prevents Porsche from including this as OEM functionality similar to our Euro brethren. BUT, I wanted to give a quick shoutout @MartinHines for the INCREDIBLE writeup. Just props all around for the detailed photos, notes, etc. Appreciate even getting an in-depth view of what's behind that panel.
Old Jan 5, 2026 | 10:22 PM
MartinHines's Avatar
MartinHines
You want to ensure the SmartTop module/device has the latest firmware before you put it in your car.
For each SmartTop product there are TWO documents for you to read/reference and print out:
1. INSTALLATION CONVERTIBLE or INSTALLATION TARGA (these are the install instructions)
2. OPERATION AND PROGRAMMING (configuration settings and description of functions).
Before installation in your car, as mentioned in the OPERATION AND PROGRAMMING manual online, you can use the “M4connect” software to “configure and activate your favorite module settings”, but you can change the function settings after the module is installed in your car.
With my install I just made sure the module had the most current firmware before I installed it behind the back seat. I did the configuration later, after install.
As described in the OPERATION AND PROGRAMMING manual, you can change the default settings at any time (after the product is installed) by putting the SmartTop in “Programming Mode”.
Everything the SmartTop can do is configured with NINE different “Functions”, (Function 1, Function 2, etc.)
The default settings are shown in the Matrix photo below in green.
As an example, “Function 3” controls the operation of the Remote Top. There are four settings choices:
— Setting 0, Off
— Setting 1, HOLD (this is the default setting, because it is in green)
— Setting 2, TAP
— Setting 3, BOTH
This means you can control the opening or closing of the Targa top by (Setting 1) holding the appropriate key fob button for three seconds, OR (Setting 2) tapping the key fob button three times, or (Setting 3) both
SmartTop Function matrix
The OPERATION AND PROGRAMJING manual can be confusing, but if you read it enough times you can understand how everything works.
A few days after I installed my SmartTop, I spent one hour in my driveway, in my car, a printout of the Operation and Programming doc in my lap, teaching myself how to change the settings.
Here is a direct link to the OPERATION AND PROGRAMMING manual:
https://www.mods4cars.com/sms/db/sma...on_v1.0/en.php
Old Jan 5, 2026 | 10:38 PM
Shogunade's Avatar
Shogunade
Originally Posted by Guzzgreg
Read the post still confused about current firmware...MAN. Sorry I'm not as tech savoy as you...MAN. And BTW thanks for the answer...MAN.
Old Jan 6, 2026 | 02:12 PM
Guzzgreg's Avatar
Guzzgreg
Thank you Martin I very much appreciate your response. That cleared up allot. And the paper clip idea was great.
Old Jan 9, 2026 | 11:58 AM
Guzzgreg's Avatar
Guzzgreg
Done...again many thanks to Martin for his incredibly informative write up. Not allot of room to plug in that tie in cable on a Targa. Used dental picks to get the red tab unplugged. Great not to not have to hold the button the whole time while the top opens.
