Safest, easiest way to increase power?
Old 07-23-2024, 11:12 AM
F8T and 911T
F8T and 911T's Avatar
Default Safest, easiest way to increase power?
I don’t like modding my cars (actually never have) but I feel I gotta do something on my 23 T if I’m going to keep it. I’ve gained confidence in its handling and braking thankfully but it’s just so slow that it’s annoying me. When I stomp on it, it makes a bunch of noise that sounds pretty good but doesn’t go anywhere… to the point where I can actually say and laugh to my passenger, ‘it sounds pretty good right? but we aren’t going anywhere; sounds like we’re going fast though’ … all before it even shifts to the next gear.
so, what is the best way to increase the speed of these cars? Is there a tune available that WONT damage anything or set off CELs? Tune plus exhaust maybe? Something not too expensive or that will not hurt the reliability or mechanics of the car? I’m VERY in favor of leaving cars alone and believe they are best from the factory, especially with Ferrari but maybe there’s something less risky for Porsche that I can have done WITHOUT voiding warranty… is Porsche **** about tunes and voiding warranties like Ferrari is? Or are they ok with a reasonable tune and will still keep warranty in tact?
thanks guys for any real world advice. Who has tuned theirs or done some other mod to make theirs faster, quicker?
Popular Reply
07-23-2024, 11:31 AM
ipse dixit
ipse dixit's Avatar
Received 11,774 Likes on 5,139 Posts
Trade the T in for a TT or TTS.
That's the safest and easiest way to increase power.
Old 07-23-2024, 11:31 AM
ipse dixit
ipse dixit's Avatar
The following 13 users liked this post by ipse dixit:
alaris (07-24-2024), asuresh8 (07-23-2024), F8T and 911T (07-23-2024), FC356 (07-23-2024), Fishah (07-23-2024), freesole (07-23-2024), Galvano (07-23-2024), GTSFella (07-25-2024), Hunky (07-23-2024), M3Inline6 (07-23-2024), silverscooby27 (07-25-2024), Tass (07-24-2024), tourenwagen (07-23-2024) and 8 others liked this post. (Show less...)
Old 07-23-2024, 11:34 AM
Hunky
Hunky's Avatar
Sounds like you might be well served by trading for an "S" or "GTS" and skip the tuning of your current "T" which it does not sound as if you are anxious to do.
There are always alternatives and a trade may be a very good choice. Good luck whichever path you take.
Old 07-23-2024, 11:39 AM
F8T and 911T
Thanks. That seems reasonable as I’d probably feel better having it all factory/stock than modifying mine… I should go drive a GTS or Turbo S to see the power difference first of course… and then also might be hard to find one in a color I want with aerokit etc but that’s definitely a path I’ll look into
Old 07-23-2024, 11:43 AM
adm63
adm63's Avatar
+1 for trying the turbo S
Old 07-23-2024, 11:44 AM
Fishah
Fishah's Avatar
Received 1,425 Likes on 515 Posts
The T was never designed to be ultra-fast in a straight line... It was about the emotion of driving. Sounds like you bought the wrong car.
Didn't you just trade for a GT3 though?
Old 07-23-2024, 11:53 AM
Hunky
Hunky's Avatar
Try the "S" also which has more ***** than the base engine and you will feel the approximate additional 100 Lb Ft of torque.
Old 07-23-2024, 11:57 AM
Newusername
Newusername's Avatar
Curious to hear what you came from, I previously had a 991.2 Carrera S and this T doesn't feel much different in the power department. Not sure if the 992 CS would be that much of an upgrade, GTS maybe, TT/TTS for sure.
Old 07-23-2024, 12:13 PM
Hunky
Hunky's Avatar
There is quite a difference between the 992 Base and the S which is well demonstrated by pro tuners baseline plots:
Old 07-23-2024, 12:18 PM
Staffie Guy
Staffie Guy's Avatar
Received 1,414 Likes on 685 Posts
I think a lot of the oomph comes when accelerating at a higher rpm. I think a 360 ft lb of torque car will accelerate with more power in 2nd at 3500 rpms than a 450 ft lb of torque car will accelerate in 3rd at say 2500 rpms.
Try dropping down a gear before accelerating if you think your T has no power,
Old 07-23-2024, 12:23 PM
Fishah
Fishah's Avatar
His frame of reference is an 800 horsepower Ferrari. Of course the T is gonna be slow.
But yes, the powerband of the T is such that it won't give you that kick in the *** that even an M3 will give you. You have to rev it out, and the power comes on progressively.
Old 07-23-2024, 12:28 PM
Hunky
Hunky's Avatar
Of course dropping a gear will change the "feel" but the engine with over 100 more Lb Ft of torque will twist the SOTP meter to a greater degree across the board. Torque is what makes a car fun to drive and what you feel every time you push the go pedal to any degree.
Old 07-23-2024, 12:39 PM
Shogunade
Shogunade's Avatar
Received 2,007 Likes on 1,129 Posts
Given your RL handle, ^^this is the way.
Puts a smile on your face every single time.
Old 07-23-2024, 12:55 PM
F8T and 911T
All good points… and yes, my other cars are of course faster and more torque etc but it’s not like I’m trying to compare…. I guess it’s just natural for it to feel slow after driving the F though:.,. I mean, I still enjoy the car and it’s fun and ‘spirited’ but just wanted to know if there’s a simple and safe tune that’ll give it a bit more kick, torque and speed… it’s not like I’m trying to make it as fast as the F8 or anything. Just seems underpowered so a little bump would be nice.
Old 07-23-2024, 01:01 PM
Fishah
Fishah's Avatar
To answer your question:
- There are simple tunes available that can add 100hp or so, mostly safety and reliably.
- Porsche may or may not have a problem with it. Depends on the tune, who does it, and your relationship with the dealer.
My personal opinion is not to tune a new car while it's under warranty, but I know there are others who vehemently disagree.
The following 2 users liked this post by Fishah:
Quick Reply: Safest, easiest way to increase power?
