Simple ASS solution
[QUOTE=dudeoverthere;19550066]that is valid, i find i just have to get into the foot pedal quickly and its then remarkably non-sluggish...
And how would that work by 45 below, as I sure don't want my engine turning off at a traffic light then? Do you turn the heater to MAX? There is supposed to be a sensor that if it's below a certain temp it won't activate. But would you trust that??? I don't
There must be a F* way to permanently turn this off with PIWIS but I just haven't found it yet... the holy grail... as this (and other features) suck!
siberian
siberian
I don't understand how this is a topic... The porsche only uses *** in normal mode and I can't imagine ever being in normal mode. My AMG GTc also only did that in normal or sport mode but for the 4 years I owned it, i put it in RACE as soon as I start the car. The Ferrari is great that it wont work in any manettino setting unless your seat belt is plugged in but I've never worn a seatbelt so it's never been a thing I've thought about. I agree this is the dumbest feature to come out in a car (especially a performance car) but it's never been an issue. ESPECIALLY with the Porsche since its only active in a mode that no one would drive in. Reach in, turn ignition one click, get in, start car after 3 chimes end, turn to sport or +, wait for valves to close, drive. Simple.
F8T and 911T (07-17-2024)
There are a lot of *** solutions. Sounds like the best is to buy a 2024 Turbo S. Mine is coded out. But here's a list of other exceptions according to zee manual.
Exceptions for the Auto Start Stop function
The Auto Start Stop function is not available in the following cases:
- SPORT/SPORT PLUS active driving programs.
- PSM off or PSM in Sport mode.
- Front axle lift system active.
- "Maximum cooling output" function is activated.
- "Defrost windshield" function activated.
- At high altitudes.
- Air conditioning or passenger compartment heating on a high setting.
- Battery charge state is low.
- On upward or downward slopes.
- During internal vehicle test procedures, e.g. automatic engine checks.
- At very low or very high outside or battery temperatures.
Damn that ***.....I am talking about its feature (which *** were you thinking of
I didn't know in Turbo S it is completely disabled from the start
let us know if that is a consistent solution. i keep my climate control at 66 and at least one bar on the fan. still turns off at a light. but i don't mind it if im sitting there for 1 minute. turning the dial to sport is muscle memory at this point.
where do you have a diamond in the center with FAL? i have PDCC but no FAL and also have a diamond. it goes from left: diamond, sport exhaust, hazard, traction, suspension.
BTW PDCC is always on, that button is just for normal vs sport suspension.
i like the garage opener on the screen. it's always there when i leave the garage and pops up when i got home. easily accessible on the screen.
Gary12000 (07-18-2024)
Great, you do you. It actually makes it much easier for me when we get an extrication call for the rescue since most passengers without seatbelts have "self-extricated". A bit messier to clean up but at least no Spreaders or Cutters to deal with - and much less time pressure. I am sure you have the science and statistics to support your position. All I have is 25 years of real life experience.
The following 3 users liked this post by Drew46:
The following 2 users liked this post by M3Inline6:
718socal (07-18-2024),
F8T and 911T (07-19-2024)
i start the car with the left hand, throw the dial into Individual with the right hand (Normal, valves closed, *** off) and put the car in reverse and back out. It’s all one motion at this point.
The following 2 users liked this post by Master Deep:
F8T and 911T (07-19-2024),
Vernin (07-19-2024)
